Ford 7.3 gas engine!
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Pucsc, Jul 27, 2019.
  1. Pucsc
    Pucsc Bobtail Member
    9
    4
    Jul 27, 2019
    Diesel is now .60 more per gallon where I live, so worse fuel mileage with gas could possibly make sense. I've been very interested in this new 7.3 gasser since it was revealed earlier this year. This engine is supposed to make it's torque down low and be paired with the same 10 speed as the 6.7 diesel. I haul 23-24k combined at most, so I could see a big gas engine handling that fine. Very little info has come from Ford yet on this drivetrain, but I would love to get out a diesel. Might be a pipe dream, but I'm looking forward to this new engine. Thoughts from the pros?
    stillwurkin Thanks this.
  3. Gumboslef9384
    Gumboslef9384 Light Load Member
    126
    170
    Jul 26, 2019
    TX
    Are you saying it has as much torque as a semi? You cant compare a pickup to a class 8 truck. Why not just get a freightliner?
    Intothesunset Thanks this.
  4. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    Pucsc and Intothesunset Thank this.
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Doubt that gas engine will last anywhere near as long as a diesel. Might. But I doubt it.
  6. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    and if those spark plugs weld themselves to the heads.....good luck chuck......
    stwik and Intothesunset Thank this.
  7. Gumboslef9384
    126
    170
    Jul 26, 2019
    TX
    I dont think it would. And I heard those things are hard to stop. Not like the semis with air brakes
  8. Pucsc
    9
    4
    Jul 27, 2019
    I'm not comparing those and why would I need a freightliner to haul the light loads I haul?
  9. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Problem solved for about $12,000 if I remember right. You can buy a lot of fuel with the money you save from not buying a $70,000 pickup.
    Coffey, stwik, QuietStorm and 3 others Thank this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Jaysus...
    buddyd157 Thanks this.
  11. Pucsc
    9
    4
    Jul 27, 2019
    Nice truck but don't need a semi to replace a 3500 dodge.
    tommymonza Thanks this.
