Force to move truck during 10 hour break because of emergency
Discussion in 'Questions From New Drivers' started by Pickneytc, Aug 4, 2021.
  1. Pickneytc
    Pickneytc Bobtail Member
    6
    Aug 4, 2021
    Was on my 10 hour break then being asked by emergency personnel to move. Literally took 3 mins. Which of course reset my 10 consecutive hour break for a 14 hour restart. Do I have to restart the clock or can I pick up from where I left off? I am new to this and need help.
    NavigatorWife Thanks this.
  3. roundhouse
    roundhouse Road Train Member
    3,129
    7,023
    Jul 11, 2018
    I’d just make a note on the logs and not worry about it
    Hopefully someone else will chime in with a more knowledgeable answer
    This is one of the many fuzzy grey areas
    isn’t there a way to move the truck slowly without triggering the ELD ?
  4. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    In the old paper log days, I would have just ignored the interruption, with today's electronic tracking I would call my carrier's log/safety dept and ask them directly. Your question has piqued my curiosity a bit! Where were you taking that 10 at that caused you to be in the way of emergency personnel?
    NavigatorWife and Trucker61016 Thank this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    There is a provision for moving during a rest break as directed by law enforcement, emergency personnel should be the same.
    Just put in remarks and let safety know.
    If you refused to move for emergency personnel, they would have gotten the police to get you to move anyway, and you can not refuse their order to move.
  6. Moose1958
    15,090
    33,171
    Dec 17, 2010
    I'm going to amend my comment a bit. I never used ELDs. I retired in 2012. If you can try to keep said communication ON THE QC. This protects you if there is an issue later on. This advice about the QC means ALL contact with the carrier that has anything to do with the truck and load!
  7. Ridgeline
    22,101
    113,190
    Move the truck, note it on the log and send a note to your safety people telling them what happened and being instructed to move the truck. They should note it on their end and everything will go on as nothing happened.
  8. nredfor88
    nredfor88 Road Train Member
    1,801
    6,096
    Sep 26, 2019
    USA
    I would have moved on PC and noted the reason in the comments. No need to restart your 10.
  9. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    Most company drivers don't have PC. But I believe the safety dept can amend the comment once that day's log is certified.
    NavigatorWife and TheLoadOut Thank this.
  10. Dennixx
    Dennixx Road Train Member
    4,422
    13,923
    Feb 13, 2010
    twin cities
    We have that happen on a regular basis.
    Some good samaritan sees a trailer venting and calls 911.
    Fire department is obligated to respond and contacts motel and they call up to the room.
    Go down and explain to fire chief that venting is normal etc. Now my 10 has been interrupted.
    afaik there is no provision allowing this.
    My bosses kinda wash their hands and say "do what you think is right."
    Probably would only be an issue should you be involved in any type of incident where your past day is investigated, say like a fatal, and they find your rest was interrupted, and could be used in a criminal trial or civil suit.
    I've gone both ways..started my 10 over and let it slide. Mostly depends on how far in I am.
  11. Truckermania
    Truckermania Road Train Member
    1,159
    1,743
    Oct 13, 2011
    Sturgis,SD
    If you have PC available just use that, noting the reason for the move and it won't cause you to have to restart your clock. Otherwise just note on your log the reason for the move and go anyway when your original break is up. Your ELD will be yelling at you all day that you have a violation but nothing you can really do about that. Any LEO should be understanding if it if you are inspected so long as you note it.
