I hate fog. Not a lot you can do about it, but knowing when/where dense fog may develop might be helpful in some situations. Honestly there's not very many good forecast tools that I'm aware of for forecasting areas/times of possible dense or patchy fog in the FUTURE. This is the best I'm aware of but it also can be used to quickly look ahead for other issues, such as snow, ice, severe storms, etc. Of course present conditions awareness doesn't do you much good once you're in the middle of it.
NOAA Graphical Forecast for CONUS Area
TIP: this web site should be viewed on a laptop or desktop browser window. Use the mouse and move it down to hover over the various time slots in the "weather" column to see a graphical estimation of non-typical weather that can be expected at at given time in the future.
Having poor headlights makes travel in fog a miserable and dangerous task. Some of the better LED lights today make visibility through dense fog much or some better then other headlights. Proper adjustment is critical, too. Of course when it gets thick enough, even the best headlights aren't going to solve all the inherent problems of driving in fog. And dense fog after sunrise can be just as treacherous as before sunrise. You can quickly lose your sense of speed, rough location, and distance travelled if you drive bad fog for long enough. Driving long distances in dense fog is much easier with the help of a GPS to help keep you abreast of where you are and how you're progressing.
Fog Season Approaching
Discussion in 'Experienced Truckers' Advice' started by STexan, Sep 19, 2018.
tscottme, NavigatorWife, JReding and 5 others Thank this.
Fog forms when the difference between air temperature and dew point is less than 2.5 °C (4.5 °F)
You can go to any NOAA weather locally such as LZK for little rock and type in zip code of the area you are interested in.
You get temperature graphs that are updated every 6 hours. Where the Graph temp and dewpoints cross or approach each other is sure to be foggy.
Here in Arkansas fog is either a storm front that is approaching or has passed. So if you are coming from the west towards Arkansas in the evening after hearing about tornadoes and such (We are coming up to that season now before ice season) you can pretty much bet the farm there will be fog.
We do not get the more common morning fog as Maryland does.Canadianhauler21 and BillStep Thank this. -
Drive at a speed that you can stop in your vision distance ... just because you can see road lines it’s deadly to assume others are doing speeds higher than what they can safely stop in too
tscottme, NavigatorWife, JReding and 1 other person Thank this. -
The one scenario where adaptive cruise would be helpful... if everyone used it and just let the system follow the one in front, it would reduce fog crashes. I don't like adaptive cruise otherwise.
September is fog month down where I live. This year we may jump right over the fog and into frost. Already used the bunk heater twice. Crazy.x1Heavy, NavigatorWife and tscottme Thank this. -
Fog is a challenge. Freezing fog is a challenge on steroids. Be sure to activate your rear view mirror heaters.
NavigatorWife, tscottme and TripleSix Thank this. -
Ice fog is my favorite. Especially when it's so thick you can't see the end of your hood.
Lepton1 Thanks this. -
SteveScott Thanks this.
Get some yellow shooting glasses, helps in blowing snow also
NavigatorWife, blairandgretchen, Lepton1 and 2 others Thank this. -
NavigatorWife Thanks this.
