Buddy of mine runs the same 53' step deck trailer that I do and just got a ticket today.
He calls me up cursing a storm because they pulled him in for an inspection and wrote him up for being 41' between 5th wheel and center of the rear axles. I was like wtf? He was 35k on his rears so he had to have them spread. Apparently Fla has some kind of bridge law like California. $100 ticket to boot.
I run with my axles spread all the time. In and out of Fla. I've never been hassled. I never knew Fla had such a law. I'm trying to find where its written but cant find it.
Anyone else get hassled with 53' spread axle trailers in Fla? Anyone heard of this before? California is the only place I know and even there I've never been hassled over it.
Hurst
Florida Bridge Law??
Discussion in 'Experienced Truckers' Advice' started by Hurst, May 13, 2014.
Page 1 of 3
It has nothing to do with the bridge law. The bridge law is for weight distribution. It is to due to the turning pivot point of the trailer when cornering. Don't need as much room in the oncoming lanes when making a right hand turn.
http://www.cargoagents.net/resources/stateroadweightsizelimitations.htm
The above is a list of all the Bridge laws. Learn it, live it. We can't have you running around like a bunch of hooligans.Hurst Thanks this. -
http://www.dot.state.fl.us/statemaintenanceoffice/2010TruckingManual.pdf
check out page 16 of this .pdfHurst Thanks this. -
try page A16 of that Atlas thing they talk about
Below is the law for which your friend was ticketed. Remember there are only 90000 laws passed each year. You are responsible for learning them all. Unless you are a Democrat and then what the hell.
2. A semitrailer which is more than 48 feet but not more than 53 feet in extreme overall outside dimension, as measured pursuant to subparagraph 1., may operate on public roads, except roads on the State Highway System which are restricted by the Department of Transportation or other roads restricted by local authorities, if:
a. The distance between the kingpin or other peg that locks into the fifth wheel of a truck tractor and the center of the rear axle or rear group of axles does not exceed 41 feet, or, in the case of a semitrailer used exclusively or primarily to transport vehicles in connection with motorsports competition events, the distance does not exceed 46 feet from the kingpin to the center of the rear axles; and
b. It is equipped with a substantial rear-end underride protection device meeting the requirements of 49 C.F.R. s. 393.86, Rear End Protection. -
After looking at the law a bit, I would say the phrase
In Florida if your spread is over 96 inches they count it as two seperate axles. With that spread you would only have "one" rear axle and it can not exceed 41'. If you have a 53' spread in Florida you need an over length permit. The good news is they have a permit good all year and its cheaper then the ticket I believe.Truckermania, 281ric and Hurst Thank this. -
I was gonna say you can buy a Kingpin permit in Fl.
Also. Mn. has the same law as well. Trust me I found out the hard way. Warning and get a permit like now before you leave
Page 1 of 3
