floating gears
Discussion in 'Questions From New Drivers' started by 7060, Oct 2, 2010.
  1. 7060
    7060 Light Load Member
    55
    5
    Oct 2, 2010
    I am just learning to drive a truck. Its a 2001 Volvo with a N14 and meritor 10 speed. From what I understand this transmission is synchronized, is this right? I am having issues with grinding the gears when floating. I can float the gears in my pickup just fine without a sound, but this is a little bit different. Looking at the ratios it looks like from 1800 you should drop down to 1300 before shifting up. Do you guys have any tips?
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,334
    Nov 18, 2008
    CA...gold discovery foothills
    1800 is far to high to be shifting...especially trying to float...since you are just beginning, perhaps it would be better if you learned to double clutch correctly, when the experience level gets a bit better, then work on floating. the majority of the testing sites for your CDL don't allow floating...just do it the right way at first.
    Learning the proper shifting points in relation to RPM's using the clutch will help you later when learning how to float the gears. and NO...big rig transmissions aren't synchronized...that is why you double clutch...TO GET THE GEAR/RPM'S/SPEED SYNCHRONIZED!
    Your pickup is synchronized...try double clutching your pickup...you won't be so smooth in acceleration!
  4. Ranger_309
    Ranger_309 Medium Load Member
    450
    753
    Sep 26, 2010
    I don't know of any synchronized transmissions in class 8 CMV's but I do know that most DOT/DMV tests require double clutching. Once you get that down, float the gears all you want too. Everyone does, who drives.
    All of us old timers wouldn't even think of using the clutch unless you really need to like on a major upgrade or something. You need to get the feel for floating gears at first. After a while its all automatic and you just do it without even thinking about it. One tractor will always shift differently then another, even if the drivetrain is identical.
    "Remember Luke, use the Force, always" :)
  5. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,292
    Dec 15, 2008
    Rochester, NY
    I am almost too embarrassed to post this but....
    I've been driving a truck for over 16 years now. While I understand a d k ow how to "float gears", I very rarely do!
    I was taught that the clutch was there for a reason. If the manufacturer didn't think it was needed, they wouldn't have wasted time, weight, and money installing one! So someone explain to me, is that correct or wrong???
    Btw, I have never tore up a clutch or transmission by using it for what it was designed to do.
  6. Blue Screen
    Blue Screen Light Load Member
    127
    108
    Jan 29, 2010
    Atlanta,GA
    What otherhalftw told you is right on the money. learn to shift the normal way first. After you learn how to turn Your Speed,Eng. RPM,& The Gear into a smooth shift every time floating gears will be like advance child's play. I believe you should drive your truck as smooth as possible. I remember my 79 year old teacher (50+ years driving) taught us how to use the clutch to smooth out your floats so it's doesn't go all cowboy. He used a clear plastic bottle with a level mark filled 1/2 with dyed water. I can still hear him say on our way out the yard: "You don't spill my water kid:biggrin_25510:, and everything else will be all....right"
    otherhalftw Thanks this.
  7. bigcountry30
    bigcountry30 Light Load Member
    278
    63
    May 17, 2009
    Indiana
    You are completely fine using the clutch. It's more of a PIA to me but I know a couple people that always use the clutch. Whatever is comfortable for you then do it. Your actually doing it the right way but floating will do no harm if it's done right also.
  8. Hubcap
    Hubcap Medium Load Member
    547
    1,547
    Dec 29, 2009
    Rhome Texas
    I used a tennis ball on a string. If you got the truck jerking, the ball would thump you in the forehead reminding you to ease into the throttle, don't gouge on it.
    Using a clutch is kinda like using a friends car: It works pretty good until you over use the privilege. Students usually over do the clutch to the 3rd power...expecting it to save their fanny and all over using the clutch will do is get you lost.
    truckerdave1970 and Blue Screen Thank this.
  9. TaylorMade407
    TaylorMade407 Road Train Member
    1,328
    1,036
    Jun 30, 2009
    Orlando,FL
    you ever see those guys who walk with a bad limp? that's because they've been using the clutch their whole careers. now think about the guys who walk normal, they are floaters. now i highly recommend double clutching at first so you can get a feel of how your truck drives and also perfecting double clutching. i remember when i first started floating i was real heavy and had to go up a steep incline and had to stop and start of a couple time cause i wasnt perfect at it so i had to double up the steep hill. but now i float the whole hill. so my advice is to perfect doble clutching
  10. Hubcap
    547
    1,547
    Dec 29, 2009
    Rhome Texas
    I limp, therefore I clutch..and float and drink way too much coffee.
  11. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    Start rolling backwards really quick don't they. Especially when running heavy. Been there done that. I agree, perfect double clutching before you start to float.
