Question for my truck experts - does anyone have suggestions on a "battery tender or float charger" I could use for my show truck?
Unfortunately because of this virus, my rig is sitting far longer than I planned on (not used commercially). And I am worried the batteries will die. But at the same time I don't want to just start it and idle it, or take it for short drives. Because from what I'm told that's not good for the DD15 motor.
I'm not looking for a high-end charger. I am looking for a way to keep a simple, ongoing charge to the four batteries. Similar to what people do with the old cars that sit during winter. I do not want to disconnect them or charge them individually. I am sure there is a tender on the market with enough amperage to maintain all 4 in series, while also monitoring the amperage so as to not overcharge them. Problem is most people don't own a semi truck that sits in the garage for months at a time. So research online has not yielded much info.
Any insights based on experience would be appreciated. Affordability is priority. Links or product names would also help if you have them. Thx gang
Float charger for semi that sits for extended times
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JoeF2002, May 6, 2020.
Not used it yet as it arrives tomorrow. But I just ordered this item.
https://www.amazon.com/ALLPOWERS-Po...TQSNXMDS5C5&psc=1&refRID=W7ZMW201QTQSNXMDS5C5JoeF2002 Thanks this. -
10/2/50A 12v Manual Charger With Engine Start
This is what I currently use. I use the lowest setting and it keeps it fully charged. It works with all 4 batteries still in connected in parallel. I have also used a Viking charger, but it was a previous model of the one they currently sell at Harbor Freight.
https://www.amazon.com/Automatic-Ba...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVlJoeF2002 Thanks this. -
I'm not trying to be a jerk, but what kind of show truck has a DD15 and isn't a work truck?
lester, Rubber duck kw, TheLoadOut and 1 other person Thank this. -
How do the Solar Chargers do , I've seen a lot of them lately on top of sleepers.
(future commenters please stay focused on the charger question. I'm well aware of how many aren't fans of this version or truck style)Bean Jr. Thanks this. -
not sure yet, but the reviews seemed ok. Though TBH I should have read it a bit more. It is a trickle charge to keep things from draining it via normal use. Like alarm systems and other constant running electronics on the modern vehicle.
I was looking for something to offset the drain of a 150 watt inverter I am using to charge my laptop battery. -
Cool truck, I like it. My neighbor kids call my truck Optimus Prime because it actually does transform. Just into a crane, not a robot
My truck sits for extended periods of time too. It only goes out when I have a job that requires it. When it's home I have one of these to maintain the four group 31 batteries:
Cabela's Pro Series Onboard Marine Battery Charger : Cabela's
They used to make larger versions that will maintain multiple battery banks. I don't see them now but since Bass Pro bought Cabela's they have been eliminating Cabela's branded stuff. There's a Bass Pro version but I don't know how it comparesJoeF2002 Thanks this. -
JoeF2002 and RocketScott Thank this.
I have been using Battery Tender brands for years on motorcycle, tractor, spare semi, and extra pickup that hardly gets driven. Big improvement is my motorcycle battery life. Last one went 7 years. They never last very long. Back up semi is kept on tender and they are 9 years old. They do need replace soon.
They charge and discharge to keep battery conditioned.
Hope this helps.JoeF2002 Thanks this.
