I I have a 1995 Freightliner FLD 120. The truck rides and handles so perfectly. It's a pleasure to drive
The only problem that I have is that I seem to have a traction problem at times. I've been in a lot of air ride tractors and they all seem to have traction problems especially when you're bobtailing.
But my truck seems to be worse. I kind of just have accepted it but I was speaking with someone the other day that got me thinking about maybe there's something I can do about it.
For example, when I pull out of my driveway it's low at the bottom and then I go over the crown of the road. Even pulling out very slowly if I'm bobtailing I have to have my axles locked or I can't get out, my wheels will just spin. I have to be careful when I pull out because all the sudden the wheels will grab. Thank God no one runs my truck but me or I'd be replacing axles and pinions.
I don't run the truck a lot nowadays so I can't remember even how bad it is with the axles locked but I seem to remember one time I got the truck inspected and the same thing I went to pull out onto the crown of the road, and even locked I had a hard time getting out. Unfortunately I do not have full lockers.
Pretty much everything on my truck is new. New airbags, new leveling valve, ride height is set exactly where it should be, new bushings.
Like I said I just kind of have accepted that's how it is, but is there any way to improve it?
FLD 120 traction
Discussion in 'Ask An Owner Operator' started by Dino soar, Dec 30, 2023.
The only things that I can think of that may help a little are to replace the lines from front to rear airbags with larger lines and maybe adding lines to help air equalize more quickly, and/or adding a quick dump leveling valve.blairandgretchen, Rideandrepair, Iamoverit and 1 other person Thank this. -
some suspensions are better than others but really not much you can do. Other than..
1 go faster, carry speed then ease off the throttle before spinning
2 put in a locker
3. keep the truck on the inside of the crown, don't cross it or straddle it.
I've had several times backing in or pulling out of driveways empty one side of the truck the tires won't even touch the ground. had to go find big rocks and scrap lumber to grab some traction to get moving.
I put a locker in the rear axle. when pulling out of a driveway if I start to spin I just stop and engage power divider and locker and walk right outblairandgretchen, Rideandrepair, cke and 3 others Thank this. -
Spent lots of time in FLD’s of close to the same vintage. All of them acted similarly to what you describe. Did ALOT of drop and hook (4 or 5 different trailers in one day) on gravel/dirt lots and they’d all hang up once in a while on a pot hole or depression. I wouldn’t mess with what’s not really broken
Magoo1968, Rideandrepair, cke and 3 others Thank this. -
My FLD was terrible off pavement on uneven ground when I was hauling cattle. I forget who made it or what the part number is, but you can get a leveling valve that dumps and inflates quicker. That’s what I did and it made a huge difference. You just have to get used to hearing a blast of air all the time when you’re driving.
Magoo1968, Rideandrepair, cke and 4 others Thank this. -
Mine is the same way.
Dino soar, Oxbow, Rideandrepair and 1 other person Thank this. -
I'll have to look into a quick dump leveling valve. I would imagine that would help. Great advice.Oxbow and Rideandrepair Thank this. -
Some guys have said that I think they use two leveling valves or somehow they tied the two airbags on one side like they made them separate from the other side somehow.
I'm not quite sure the right way to say that but I know the guys in the dump trucks have told me they did that and it stopped the side to side roll whatever it was that they did.
If anyone is familiar with that, would that make any difference?Rideandrepair Thanks this. -
