FLD 120 or Classic??? I need your help
Discussion in 'Ask An Owner Operator' started by D.J.C, May 24, 2016.
  1. D.J.C
    D.J.C Bobtail Member
    13
    May 24, 2016
    I'm wanting to become an o/o. I've been looking at a lot of trucks but I have two that I keep coming back to. That's where I'm needing your help.
    Before I continue I think I need to explain why I'm considering these two. I'm planning on leasing on to sni choice, pulling dry van. 1) I'm wanting to buy a truck that I can pay off in a year, 2) I want a pre-emissions, per-erg truck, and 3) I want a Detroit. Both of these trucks have Detroit's, both are freightliner, and both have the 70" condo sleeper.
    Ok, truck 1) 2004 freightliner FLD132 Classic XL, 14L (pre-egr) set at 475hp now, 13 sp, with 3.55 gear ratio, 22.5 lp aluminum wheels, and 260" wb.
    Truck 2) 2001 freightliner FLD120, 12.7 (pre-egr) set at 500hp, 13sp, can't recall gear in this truck, 24.5 lp aluminum wheels, and 240"wb.
    Both trucks have been overhauled recently. While the classic is $30,000 and the 120 is $20,000.
    What truck would you choose and why?
  3. Rex012
    Rex012 Light Load Member
    256
    76
    Apr 12, 2014
    Classic xl cause it looks better. But the fld will probably turn better. But the classic xl looks way better to me and has been my dream truck but can't get one. I live in CA..
  4. Eeyore05
    Eeyore05 Medium Load Member
    311
    287
    Nov 13, 2015
    'Sconni
    Have you checked into if they have an age requirement? Most companies want less than 6 years old to lease on. Good luck.
  5. Eddiec
    Eddiec Road Train Member
    2,191
    3,358
    Feb 2, 2015
    SNI age requirements on outside trucks for Van division is 10 years. You may also check the availability to bring your own truck in as a contractor.
  6. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    Yep, both trucks are too old for Schneider and from reading post from those over there now they are not really taking on new O/O’s unless they are leasing from SFI and even then there is a wait now to get on the program.
    Probably best to contact them or any other company you are considering directly for the current information before wasting a lot of time looking at trucks you can’t lease on there.
  7. D.J.C
    13
    May 24, 2016
    I'm currently a company driver for Schneider. As a company driver I can lease on with these trucks. I was told it had to be a 97' or newer truck so that it would be compatible with all their electronics they put on your truck.
    Rex012, I agree. The classic is the better looking of the two.
    Rex012 Thanks this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Im going with the FLD 120. The classic would be nicer. But the 120 will run, the one weakness is it's front end. Hit a big enough pothole in seechiago....
    The avatar under my name in the picture is a full 1995 FLD 120 with the 490 detroit in it. That one was a Ronnie Dowdy Road Trip truck I took over for myself roughly 7 wonderful months. I was usually in the left lane with it loaded on the governor which was around 72 in those days. Ran 15000 miles a month or a touch more in it. It was without question one of the very best trucks I have ever had the joy of kicking around the USA.
    The second best would be the 2001 Century That we picked up new with it's cherry less than 200 miles but the automatic broke down software wise causing us to be towed twice losing two accounts. We were a team and that thing never stopped so the transmission could not reboot until it finally just filled up with binary and quit.
    30,000 for one, 20,000 for the FLD. I would go with the 20K, FLD, stick the 10K in the bank against future trouble which will come up in time. Better to have the money building up slowly against that bad day sometime in your future than no money and beggaring.
    Oh one more thing, run that FLD with aluminum wheels. Don't give it heavy steel wheels. You will hate it.
  9. D.J.C
    13
    May 24, 2016
    I'm currently a company driver for Schneider. As a company driver I can lease on with these trucks through their company to independent program. I was told it had to be a 97' or newer truck so that it would be compatible with all their electronics they put on your truck.
    I have concerns about both trucks. Like with the classic, I'm not as familiar with the 14L, what kinda fuel mileage I should expect in the truck, cost of an overhaul or reman for the 14L when it comes time, or common problems I should watch for and so on.
    With the FLD120, will the 24.5 wheels hurt the fuel mileage, and of course the same concerns about cost to overhaul or a reman when needed.
  10. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    24.5 wheels? The larger wheel diameter means less revolutions per mile. You have more horse backing it so you should need less cruise power at the drives after accounting for the parasitic power losses at your engine, transmission, pumps and so on.
    If you have the ability to take both trucks for a spin, evaluate them with a eye on your fuel burn per hour. Aviation pilots do this always and that information is availible to truckers as well, but not always present on the dash you might have to get it from the engine's computer via the diagnostic hookup. The 120 should do less fuel per hour because it has more power on tap. You can put it on God's golden staircase going straight up loaded in low gear and burn 30 gallons an hour. A day's work would be that for your 300 gallons .
  11. D.J.C
    13
    May 24, 2016
    Sorry didn't mean to repeat myself. Lol. The 120 has all aluminum wheels already x1heavy. So I guess that's one less thing to worry about.
    x1Heavy Thanks this.
