Flatbed trailer dimensions
Discussion in 'Flatbed Trucking Forum' started by DuesyJ29, Feb 26, 2015.
  1. DuesyJ29
    DuesyJ29 Light Load Member
    78
    35
    Jul 19, 2013
    Dallas, Texas
    I'm looking for the typical deck height of a standard flatbed trailer. I may need to move an antique railcar body that is 10' 1/4" high by 8' 5" wide by 45' 6" long. I don't want to be over height and I'm worried at this point that I might be.
    Thanks,
    Mike S.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    Somewhere between 56" and 60" depending on rail height and 5th wheel setting.
    Sounds to me like you would be better off with a travelling axle Landoll, unless you can find a short neck 53' stepdeck.
    One of my old tilt deck trailers, probably should have kept it,
  4. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Or a sliding Stepdeck. They are made to extend the lower bed. They could easily extend to accommodate your rail car. Good Luck
  5. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    5 feet high. It would be too tall. Anything over 8.5 feet high gets to be difficult.
  6. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    You could get any 53' step to haul that. Most are 40-42" tall on the lower. If you get a spread axle they should not have a problem with weight distribution. My step is only 36" high on the lower deck. You also need to figure how to get it up on to the trailer. If you dont have a good way to get it up there, or it cant go up 16' of ramps, you should look for the type of trailer Kansas posted a pick of.
  7. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    10' 1/4" and you haven't added any dunnage.
    KANSAS TRANSIT Thanks this.
  8. xsetra
    5,092
    6,939
    Aug 21, 2011
    My step would carry it Height is no problem. Weight depends on how heavy it is. I sit 36" off ground. But my lower deck is 38' long. Your car would over hang about 7-8'. I would have no problem transporting it. IF the integrity of the car can handle it.
    OP why is overheight a problem. Just a matter of getting permits. Or is your building door opening limit the height. Legal high in Texas is 14' plenty room for dunnage under car. IS the rail car body going to be loaded with or without its cars.
    Easy to load rail car. Use a crane and sling it. No different than loading a bulk round storage tank. Good luck.
  9. Ruthless
    Ruthless Road Train Member
    8,786
    85,967
    Aug 28, 2010
    The City.
    What's the weight? Only railcars I've seen trucked are on extendable double drops and are heavy enough to warrant extra axles.
  10. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Or you can do what we do....
    This one is a little longer and shorter but a 5th wheel plate and a dolly is what we use. You will be right around 14-15 feet.
  11. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    20,065
    Oct 23, 2008
    Wichita, KS
    I see your location is Dallas. If that's the area where your needing to move this car we have extendable step decks and RGN's at our DFW terminal location that can handle the length, height and weight unless it's built from lead.
