Flatbed Terminology
Discussion in 'Flatbed Trucking Forum' started by BulletProof, Mar 1, 2013.
  1. BulletProof
    BulletProof Medium Load Member
    503
    322
    Feb 17, 2013
    Alabama
    After extensively reading through the flatbed part of the forum, I have come to realize that there are MANY terms that I am not familiar with (shotgun, suicide, skidded, v-board, explanation of the different types of tarps 'coil', 'wood', 'steel' etc) and I'm sure there are quite a few other aspiring flatbedders in my same shoes. I thought it would be nice if people would chime in and post different terminology used in the flatbed world and define it and I will compile all of it into this comment so it could be used as a quick reference. I'm sure it would help myself and a lot of other newbies.
    Acronyms:
    WLL - Working load limit
    Tarps:
    Coil tarp - A tarp specifically designed to be used with coils
    Lumber tarp - 6 -8 side drops with end flaps
    Smoke tarp -Covers front of a load to keep soot or other debris off.
    Steel tarp - A tarp for covering steel, usually only has a two foot drop.
    Drywall tarp - One piece, but has flaps front and back. Usually 6' drops and 25-30' in length
    Coils:
    Suicide - Coil can roll onto the truck
    Shotgun - Rolls off the side of the trailer
    Skidded - Coil on a pallet
    Chains, Straps, and Boards:
    Snap binders - Chain binders that snap tight. (Can be dangerous)
    Cross chain - From one side of load to opposite side of trailer.
    Deck chains - Chain pots that have been installed in the top of the deck. Useful for chaining triple suicide coils and such.
    Gut Strap (Belly strap) - strap going through middle of load. Generally used on loads more that 3 tiers high. Will prevent forward shifting of bottom layers and also (on tall loads) prevent the middle sections from bowing out and collapsing. Gut straps DO NOT count towards straps needed to meet weight requirements.
    Direct tiedown - One side of trailer to the load back to the trailer or tiedown. WLL is cut in half when using direct tiedowns.
    Indirect tiedwon - Goes from one side of the trailer over the load (or through the load) and to the other side of the trailer. WLL is doubled when using indirect (additional info see post #16)
    V-Board - Edge protection that goes under the strap
    Dunnage - Wood/lumber
    Trailers:
    Rub Rail - Reflectorized rail (usually) that goes around outside edge of trailer. On a 102" trailer, entire load must be within the rail.
    California spread - 53' flatbed trailer that is CA bridge law legal. Usually evident by 6-7 feet of overhang on back.
    mpow66m, Blue jeans, themetro and 33 others Thank this.
  3. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    Shotgun & suicide is how a cool is loaded ,if coil can roll onto truck it's suicide,shotgun roll s of side of trailer.Skidded is a coil on a pallet.V board is an edge protection goes under the strap .A few tarps,coil tarps enuf to cover the coil. Lumber tarp 6-8 side drops with end flaps.
    Blue jeans, D.Tibbitt, Razor3 and 2 others Thank this.
  4. superpet39
    superpet39 Road Train Member
    1,161
    619
    Jan 27, 2013
    Bay Area California
    I saw a newb ask a question about a term the other day(can't remember what it was) but it got me thinking............maybe there should be a "trucker terminology 101" on here lol
    RedRover Thanks this.
  5. critters
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    there is it called " the old timers "
  6. BulletProof
    503
    322
    Feb 17, 2013
    Alabama
    That is kinda what I'm trying to accomplish here except strictly flatbed terminology.
    chief890 Thanks this.
  7. BulletProof
    503
    322
    Feb 17, 2013
    Alabama
    Keep them coming guys!
  8. RedPete95
    RedPete95 Light Load Member
    176
    39
    Feb 5, 2009
    Erie, PA
    How about snap and ratchet binders. Some trailers use "J hooks" that go into a track on the deck and thats the securement method. Winches and the different sizes they come in 4" track winches,2" & 4" ratchet winches, the winch bar to operate them, Coil racks for hauling those suicide or shotgun coils.
  9. BulletProof
    503
    322
    Feb 17, 2013
    Alabama
    Need a little more clarification so that I can format it the way I have the others at the top.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    A coil tarp, or bag, is a tarp that is specifically designed to be used with coils, not enough tarps to cover coil.
    BulletProof and 406onthego Thank this.
  11. BulletProof
    503
    322
    Feb 17, 2013
    Alabama
    Ok I will change it.
