I'm starting a new job where i have to use side kits and have not done before.Have over 20 yrs driving experience and have done oversize and flatbed.Just wondering if any tips i can use from you guys.Will be pallitized loads i think and not always whole load.Wondering how best to start ,as they load, when to put bows up and then tarp.Tarp as they load, wait till done Just wondering. Thanks Bob
Flatbed side kits install and uninstall
Discussion in 'Flatbed Trucking Forum' started by bigbob486, Apr 22, 2012.
You are putting a side kit with tarp on a flat bed, correct?
I used to pull a Conestoga wagon, it all depends on the load and where you load and unload with respect to the side kit.
When picking up or delivery just pull the bungees front to back, flip the tarp over to the passenger side of the trailer and have then load from the drivers side. -
Thanks yea flatbed with side n tarps guess I'll just figure out as I go.g
A few times and you will be flipping bows fast, just keep in mind to watch the bows and not bend them. If your flatbed does not have deck chains or d rings for securing just set up your sideboards and take a small fine blade reciprocating saw and cut small V notches at the stake pockets.
DSK333 Thanks this. -
Ok. Thanks I was wondering to tarp should I tarp as they load setting up sides and bows or wait till done I don't think it's going to be full loads
It depends on what you load and how they load it. We used to haul palletized lumber which they loaded from a dock, no need to break down anything. Something like coils loaded by an overhead you will only have to undo the tarp and move a couple bows to get it on the trailer. Steel loaded from the sides you will have to undo the tarp, take the bows out and take down one or both side, depending on how they load.
