Flatbed pros and cons
Discussion in 'Questions From New Drivers' started by Western Sky, Mar 29, 2012.
  1. Western Sky
    Western Sky Light Load Member
    67
    34
    Feb 2, 2012
    Oregon
    Would you mind giving your input on the good and bad of pulling flatbed? Thanks in advance.
  3. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    good
    - exercise, some loads a little, other loads a lot
    - usually no waiting at receivers, they're waiting on you to get your equipment off
    - get to be outside in the nice weather
    - learn a skill that can be used to get into other trucking areas such as oversize/heavy haul
    - get to take pride in what you do and how your load is secured
    - typically better pay than van drivers
    - longer distance loads are more frequent, not as much having to drive down into cities to deliver either
    bad
    - tarping in the wind and rain, rolling/unrolling frozen tarps
    - have to do laundry more often than van drivers, dirt happens
    - might have to buy tools for the job at times (hammer, nails, etc)
  4. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    The good... More of a challenge strapping and tarping.
    The bad... Having a bunch of pipe come through the cab of your truck.
  5. Western Sky
    67
    34
    Feb 2, 2012
    Oregon
    Are the miles and work pretty steady and consistent ?
  6. Thatguyfromtexas
    Thatguyfromtexas Bobtail Member
    36
    20
    Feb 19, 2012
    Norman, OK
    That depends entirely upon who you are working for. Some companies haul 99% pipe, others haul whatever they can find.
    Usually lots of miles, pretty hard work when your not driving, steadily behind schedule and consistently away from home.
    You'll either love it or leave it. Few seem to find middle ground.
    Tarping is a pain, forget about staying clean, and ALWAYS throw an extra strap or chain on your load.
    And I don't think they could pay me enough to pull a van or reefer.:biggrin_255:
  7. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    The two quotes I highlighted arent quite true. I go into lots of cities all the time and have waited long times to get loaded oe unloaded. I was just at carry on trailers in winnemucca, nv and spent 8 hrs and 15 minutes there trying to get loaded.
  8. nicholas_jordan
    nicholas_jordan Medium Load Member
    608
    101
    Mar 31, 2012
    temple texas
    if you are as described in your description - wannabe - then go work in some place that hauls equipment before trying to do flatbed as one has to be able to stand 20 degree blowing wind and chain a boomer or strap the load with ice on the trailer deck which is 5+ feet off the ground with some supervisor or whatever watching that is sorta mad and has to get it loaded and do that without slipping off the deck on the ice = it can be done but that is not for wannabe's ~ try city delivery to start if you seriously wanna be a trucking professional,....the work of city traffic is not what flatbed operator sees a lot of but when it is there that can be the risk none of us wants
  9. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    You get outside in the fresh air with flats. Pay tends to be higher than pulling a van. Pulling a flat means that you will usually get dirty when you tarp and at least 50% of all loads will need to be tarped. Some carriers require ALL loads to be tarped. It can be aggravating to be tarping when the temperature is over 100 degrees or below freezing and it is snowing, raining or sleeting. You will take on more responsibility pulling flats. It will be up to you to learn how many chains or straps are required by each load. No two loads are exactly the same. Those of us who have pulled open deck trailers for a while would not want to do anything else. I can't imagine going back to pulling a van. Some people are not cut out for flats. It takes a little more thought and time to load when you have to tarp. On the other hand, I do less waiting to get loaded or unloaded as a general rule. There have been exceptions. People are more interested in seeing you than if you pull a van.
  10. albhb3
    albhb3 Medium Load Member
    596
    279
    Nov 3, 2009
    Cons or a plus you can still get that 400lb physique. No im not joking around
  11. fireba11
    fireba11 Heavy Load Member
    864
    541
    Jul 30, 2007
    Tracy City, TN
    lets not forget the chaining and tarping in 95 degree 100% humidity weather either!
