Flatbed length question
Discussion in 'Questions From New Drivers' started by bergy, Nov 3, 2013.
  1. bergy
    bergy Road Train Member
    1,189
    1,311
    Nov 1, 2013
    I have tried find this answer but couldn't.
    Why is the "standard" panel trailer 53', while the most common flatbed seems to be 48'? There seems to be both, but there are a lot fewer of the 53'.
    Also, in what situation would a drop deck be better than a flat deck. I realize it is lower, but isn't a drop deck limiting your options?
    Thanks.
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Hers the deal.....In flatbed, a lot of the freight is heavy, or less then 48' long. Most of the freight we carried at tmc maxed out in weight before length. Why drive around with a extra 5 foot dovetail you rarely need? Things like insulation and large equipment (john dear) could benefit from a 53, but most will fit on a 48 so the 48 is just more practical. In vans, we haul a lot of light freight, so space is your limiting factor
    As for step deck. There are some loads you cant haul. Anything dock loaded from rear wont load on a step deck. You can haul taller loads though that you cant haul on a normal flat. Both have thier advantages for certain loads, but i feel the most flexible is a normal flat.
    Side curtain flats are nice to avoid taRping, but will prevent you from hauling crain loaded product like biig beams or steel coils. Accordian style sliding roof will prevent from hauling real tall loads like insulation and sometimes lumber. Side kits can be removed, but will prevent tall loads as well. They are much faster for coils though. If you want the most flexibility, a regular 48 flat with a normal tarps will allow you to carry the most loads. Step will get you some specialized freight but you will loos some options to. 53; is good if you have a john dear account, or haul alot of insulation, other then that its a waste. Many sheet rock companies wont load a 53' because it wont fit int he 48 dock. If they load it you would be over weight on your trailer since they cant load the front 5 foot.
    jxu417 and bergy Thank this.
  4. bergy
    1,189
    1,311
    Nov 1, 2013
    Richter - thanks for the detailed response.
    I'm trying to soak up the lingo as well, I almost sent a response asking what "taping" was before I figured it out - lol
  5. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    sry taRping
    bergy and misterG Thank this.
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Don't forget to check your trailer brakes on your skateboard when running bob tail.
    Keep the black side down and the silver side up
    Lol Jk....a skateboard is a flat bed. Bobtail means running with no trailer...so no need to check the brakes on your trailer lol
    Black side is the tires and silver side is the deck of an aluminum trailer. Basically means, dont roll it.
    Cheater bar, winch bar, lazy bar, are all the same thing and are used to tighten the straps.
    Hmm, i cant think of any other flat bed lingo lol
    bergy Thanks this.
  7. bergy
    1,189
    1,311
    Nov 1, 2013
    Great, I'm an expert now and I didn't even have to get my class A!
    The more I've been thinking and researching, the "skateboard" has an appeal to me. I've always had an inquisitive mind and an interest in big machinery and how things are made. Seems more interesting than hauling a load of plastic forks or toilet paper. I'd like to be the guy responsible for figuring out how to strap down interesting loads and get them to destination in (hopefully) the same number of pieces they started as. I understand though this board that it is dirtier and more physical work, but some of that is paid for, right?
  8. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Where are you getting your info that flatbed freight is heavy??? You were either looking in the wrong places or the company you were pulling for just liked pulling heavy freight. A lot of the big flatbed outfits pull heavy sticks and bricks. Not wise and it definitely isn't the norm with anyone pulling a flat trying to make smart decisions on freight.
    RollinThunderVet Thanks this.
  9. KF7WTV
    KF7WTV Medium Load Member
    410
    234
    Aug 8, 2012
    RENO, NV
    Yep, its more challenging. Yep, its dirtier. Yep, you get paid for SOME of that, by SOME companies.
    There is a Roehl terminal there in Phoenix that trains some of the company's skateboarders. You could stop by and ask the instructors anything you want to.
    And a side note: a winch bar has a bent, tapered end to insert into the strap winches. Hence the name. A cheater bar is a straight piece of pipe, open at both ends. Used for extra leverage on a winch bar (rarely need it), or for closing and opening chain snap binders (every time).
    bergy Thanks this.
  10. KF7WTV
    410
    234
    Aug 8, 2012
    RENO, NV
    MJ, any company (as a customer) is going to try to ship/receive every pound that it can for every dollar it has to spend. I rarely carry less than 45k # on my trailer, unless it's insulation.
    freightliner438 and Richter Thank this.
  11. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    I'll be representing the 53' flats and steps here. I love pulling that extra bit of real estate around, it is the epitome of versatility. Of course it is all aluminum but this outfit rotates in new equipment quite regularly. And the bread and butter of their loads are the heavy stuff. I do get a good share of the lighter loads over time, like today we have a load of insulation coming in at 7800#. Of course it is also 8' high and 48' long, and quite the fuel guzzler with the high profile coming across I-80.
    bergy Thanks this.
