I got the warning that I was going to get a derate in 100 miles, the DEF red light started flashing and the DPF filter gauge swung from almost clean to full. I didn't know that shutting off the truck would cause the derate immediately on the next start. I have had trouble with bad DEF before so I drained the tank and put in 20 gallons of fresh, it had been awhile since DEF filter was changed so I changed it too. My OTR tool showed no active codes except SPN 1569 FMI 31 and SPN 5246 FMI 0. I tried doing resets with the OTR tool but problem would not go away. I left the truck idling and went to sleep. 4 hours later all warnings were gone! The red light was no longer flashing and the DPF gauge had swung back to clean. Thanking God I did not spend thousands on a tow. I'm told it is recommeded to fill the DEF tank with new DEF but in this case 20 gallons did it, it's a 30 gallon tank. Your mileage may vary. I'm posting this in case its helpful for somebody else. 2017 Peterbilt 389 Cummins ISX15.
Flashing DEF Light and Derate Clears Itself With New DEF
Discussion in 'Experienced Truckers' Advice' started by FL450, Oct 22, 2023.
Years ago a kw mechanic told me 75% of def issues go away if you keep def tank full . Just don’t overfill or you may get a def quality derate . By keeping it full you get less crystals from the def drying out I guess.
FL450 Thanks this. -
Consider yourself lucky. Maybe.
It's might just be a temporary and could come back.
My def quality ended up being the level sensor. -
Have an International that has been running on the QLS patch for about 2 years now. The sensor has been replaced. The patch is still active, with no updates yet to replace it. At least it keeps any DEF related codes from being reported and shutdown from happening.
Magoo1968 Thanks this. -
We have two of those. On one.... just running the def low, resulted in having to replace the sensor. We keep it at least 1/2 full now.
The driver told me about another sensor or level sensor. He replaced it himself. Didn't want to wait all weekend till tuesday for them to get to it. ..... Definite problems with those def tanks. Keep it at least 1/2 full.
