flash code 63 help plz
Discussion in 'Trucks [ Eighteen Wheelers ]' started by free2fly973, Oct 22, 2013.
  1. free2fly973
    free2fly973 Light Load Member
    95
    11
    Mar 9, 2012
    Oklahoma
    Ive got flash code 63 flahing on shut down engine light (red) and 16 on chk eng light (yellow) from what ive gathered 16 was coolant sensor that I replaced. And 63 is something to do with pwm? Would that be my abs? Last 6 of vin # is 889732. If It is abs can you tell me which wheel. I have 2 on front; one on each side. And 2 on 3rd axle.
    Thanks for any and all help.
    Also is there a place I can go to look up parts and other spacific info for my truck by vin? Local freightliner isnt fond of doing this.
  3. porkchop_express
    porkchop_express Bobtail Member
    28
    14
    Oct 17, 2013
    Sign up for an account at accessfreightliner.com and you can look up parts for any VIN# that you currently own.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Flash code 63 is very difficult to diagnose without DDDL software. It is a pulse width modulation output issue. This may help http://dmbruss.com/images/Schematics/DDEC/63_Flash_Code_63_PWM_Fault.pdf , but without knowing the FMI, which output, or what that output is assigned to, you'll have to check them all.
    The 16 is a coolant level sensor fault. Flashing on the amber light, it's not active. It may be an old code that was repaired and not cleared, or it may be intermittent. 90% of the time, that code is a bad connection right at the sensor plug. Give a good tug on 1 wire at a time, if you pull it out, you need a new sensor plug on the harness.
