Fixing deck on wooden flatbed trailer
Discussion in 'Flatbed Trucking Forum' started by Rich_Trucking, Feb 15, 2015.
  1. Rich_Trucking
    Rich_Trucking Light Load Member
    248
    21
    Dec 11, 2012
    Hello, I have a flatbed that has some holes in the wooden deck. It's an older flatbed so I don't want to spend too much on it. I just want it to last another year.
    can I put Home Depot pressurized wood down? Is it strong enough?
    What at do you recommend for a cheap repair of wood.
    THANKS
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Home Depot pressure treated lumber is soft wood. You need to have hard wood for a flatbed deck.
    Cetane+ and SMTatham Thank this.
  4. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    From my experience, pressurized wood does NOT work at all well when used as coil lumber. It has a tendency to crack under the pressure of the load. Considering that, I don't think I would trust it as a floor.
    But! Steel coils are very heavy, and we are talking about placing all that weight in one small area. If you are not hauling coils, you MIGHT be able to get away with pressurized lumber. I would definitely talk to a trailer repair shop and see what they say about it before I went out and spent a bunch of money on wood that I can't use.
  5. Ruthless
    Ruthless Road Train Member
    8,802
    86,199
    Aug 28, 2010
    The City.
    Hardwood only. Find a sawmill have it cut to what you need.
    Cetane+ Thanks this.
  6. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    A trailer dealer with a parts dept. will have the planks you need, and you can buy just what you need.
  7. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    When I repair a deck, if it is going to have heavy weight, use oak wood. Have one trailer that only hauls palletized freight, and I us 5/4 decking on it. The same stuff used to build a back yard deck.
  8. Ruthless
    8,802
    86,199
    Aug 28, 2010
    The City.
    Apitong is big dollars-OP said he wanted to patch it up to last another year. Lot of money to spend on apitong to get rid of it in a year.
    jbatmick Thanks this.
  9. Rich_Trucking
    248
    21
    Dec 11, 2012
    Thanks guys, so nothing a local Home Depot would work Ie. 2x8 etc?
  10. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    The only hardwood I recall seeing at HD is oak trim and boards for shelving etc. Most of that is high grade and only 1" .
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I always used apitong from fleetpride. using mix matched wood creates a trip hazzard. I am also seriously thinking about getting a new trailer in march & trying to keep mine patched until then. I still find the quickest & best way is with original, or just replace trailer sooner. to reinforce my deck until I could get the supplies & time to fix, I would cut treated 2 by 4 into 11-1/2" length & put 2 under several sections of the weak parts of the floor between the crossmembers & use wood screws from the top & self tapping metal screws from the bottom. this way no matter how bad the decking is, it has no where it can go. I will try & post a pic of what I am trying to describe
