Hi guys, its my first winter on my semi truck, I have freighliner Cascadia 2021 dd15, im in kansas city right now and weather its very cold -13 Fahrenheit, can i sleep with engine off or engine should work all night?) I have webasto in sleper, thank you
First winter, do I idle in -13 degree weather?
Discussion in 'Experienced Truckers' Advice' started by Nurs, Jan 14, 2024.
Page 1 of 4
At that cold level I would let it idle all night.
justcarhaulin, Tonythetruckerdude, Accidental Trucker and 4 others Thank this. -
Another Canadian driver Thanks this.
Crude Truckin', Tonythetruckerdude, Tall Mike and 5 others Thank this.
Tonythetruckerdude, Another Canadian driver, 201 and 2 others Thank this.
Accidental Trucker, Atlanta trucker and Another Canadian driver Thank this.
I usually shut mine off down to -20 but I also had the Webasto coolant heater for the engine.
An alternative for you would be to start the engine every two hours. The 10 minutes it will run would be enough to keep the engine block warm for the morning . Although you won’t be getting a great sleep with the interruptions.Another Canadian driver and hope not dumb twucker Thank this. -
It wouldn't be a mistake to keep a bottle of this close by........
RockinChair, Another Canadian driver, bryan21384 and 5 others Thank this. -
1st winter, hey? This will make or break ya'. To be clear, these kind of temps that far south is a bit unusual. Whatever you do, DON'T shut the truck off. Save the Webasto for when its in the 20s, but this cold, return warm fuel is needed , I think Detroits return warm fuel, and if you shut it off, that's when the trouble begins. It doesn't hurt a motor to run, step it up to 1000, cruise, brick, whatever, and I think releasing the tractor brakes,( but keep trailer on) keeps the motor running, and if the boss gives you any guff, just say, "is your bedroom at home warm"? End of story. Be careful out there, eh?
Dwellsouth, RockinChair, Tonythetruckerdude and 4 others Thank this. -
I also might add when you’re running in the winter and driving through snow, slush, slop and rain, when you park for the night don’t pull your red knob. You’ll be under the trailer in the morning beating brakes with a hammer.
RockinChair, Tall Mike, mustang190 and 6 others Thank this.
Page 1 of 4
