FireStik vs. Francis vs. K40 mobile antenna
Discussion in 'CB Radio Forum' started by nj diesel, Oct 18, 2013.
  1. nj diesel
    nj diesel Bobtail Member
    42
    10
    Apr 22, 2012
    Looking to upgrade my mobile antenna. Can't go too tall so I'm looking at a 4.5' Francis or a 4' FireStik or K40 fiberglass antenna. Not too concerned with the output looking for better reception (greater sensitivity) Any experiences or opinions on these three?
  3. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    All the same animal. An adjustable fiberglass whip is the best design short of SS 102" whip. The only difference you might find is the mfg's warranty.
  4. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    768
    193
    Jan 31, 2010
    Skid Row
    The longest you are willing to mount will provide the best receive.
    Turbo-T and handlebar Thank this.
  5. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    I know the whips and Monkey Made type antennas are probably better, but I started running the Francis years ago after having run the Firesticks before that. I used to admire all the good sounding radios that the Roadway drivers used to run up I-81 and I got to looking and the biggest part of them were running the Francis, and I have since then. They don't have to be tuned, just make sure you run and change coax and mounts regularly.
  6. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Most of the freight haulers ran/run the Francis 5'5" antenna. It is a good performer because of its length. (I've got one I use also)
    puncher Thanks this.
  7. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    My father in law swears by the francis antenna's, he ran a 400 watt kicker with his and still to this day he swears by it!
  8. AnyLoad
    AnyLoad Bobtail Member
    6
    Temple, TX
    use a 108" whip if possible. and there cheap. $14 in Temple, TX area. if those are too long tram makes a square coiled antenna $29 +- They work great on the west coast style mirrors. SWR checks should be free at a cb shop, also the New K40 fiberglass if they are 4ft or longer are good too. or get creative and use the exhaust stack as a j pole antenna :) it works..
  9. 7.3 cowboy
    7.3 cowboy Light Load Member
    210
    59
    Mar 4, 2013
    I've always liked my firestiks
  10. white wolf
    white wolf Light Load Member
    287
    131
    Jul 1, 2013
    minneeessoooota
    Try a wilson silver load whip they always work well and are durable will not use cheap ### firesticks and francis they good to junk after a year or two in bad weather
  11. nj diesel
    42
    10
    Apr 22, 2012
    Yeah, I forgot to throw the Wilson Silver Load into this mix, I've heard good about them, double wound, top loaded. I'm starting to consider a Wilson 2000 or 5000 Trucker also.
