Fired the dispatcher i got T number help
Discussion in 'CH Robinson' started by rickyisgood, Dec 21, 2012.
  1. rickyisgood
    rickyisgood Bobtail Member
    Hi i let goof my dispatcher for being a prick. Can someone tell me step by step the process
    after i book the load with ch Robinson?like check ins and after the the load is delivered do i need to call ch?
    Also my dispatcher told me not to call his contacts because of chicago politics they may cancel my t number could that really happen?
    thanks
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    CH Robinson usually gives you instructions to go by as calling in for picking up a load, in route calls, and delivery calls.
    Ole school trucker Thanks this.
  4. LSAgentOZR
    LSAgentOZR Road Train Member
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    Ricky, no... he's FOS. You deal directly with CHR by calling in, giving your t-number and reporting your status.
  5. A2B
    A2B Bobtail Member
    Dec 27, 2012
    Check Their load board, call the rep on the load and give them the load#, and negotiate your rate. Don't worry about politics as they will work with you as long as you have a T#. Don't be afraid to ask for $2.00 per mi. or more. You may not get that from seasonal areas like FL,CA,TX, etc unless it's at peak season but ask for a lot more to go there. Good Luck!
  6. ladywrongway03
    ladywrongway03 Heavy Load Member
    766
    328
    Aug 28, 2008
    trotwood oh
    CH Robinson....cheap and heavy
  7. Moving on Down the Road
    Moving on Down the Road Light Load Member
    135
    37
    Mar 6, 2010
    KY
    I use their mobile app on my smartphone. Only time I need to call is for T-chek advance.
