Finding curb weight for Box Truck with sleeper
Discussion in 'Expediter and Hot Shot Trucking Forum' started by jj1, Aug 30, 2011.
  1. jj1
    jj1 Bobtail Member
    8
    I'm considering buying a box truck and sleeper, with a gross vehicle weight rating between 25,000 - 26,000 lbs but I'm having a hard time finding out how heavy of a load I will legally be allowed carry because I can't ever find the curb weight. How much will having a sleeper determine the weight I can carry? I'd like to have a larger sleeper because I plan to stay out weeks at a time. With larger sleeper, what size box will be the most efficient? 20 ft? 24, 26 ft???? I would like to carry at least 10,000 pounds. Is this even possible with a class 6 box truck without a sleeper? Why is it so hard to find a trucks weight when not loaded? I would think knowing a trucks curb weight is an important thing to know when shopping for one.
    ~Newb
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    you may have to talk with someone at a dealership, there are a slew of things that can effect the empty weight of a truck: engine choice, transmission, cab style, interior options, fuel capacity, steel or aluminum wheels, etc.
    Usually a dealer can spec a truck and tell you what it will weigh empty for those specs. And a sleep mfg. should be able to do the same.
    jj1 Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Most truckers will scale their truck empty. Then there is no doubt.
    Most truck stops have scales. Stop by one on a test drive.
    The previous owner should know that info.
    A rough estimate is around 12,500 lb for a stock 26' truck with a 7500lb load weight.
    jj1 Thanks this.
  5. jj1
    jj1 Bobtail Member
    8
    TY, for answering. I may just move up to CDL B vehicle and get some training at a school.
  6. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Get your class A, then you can drive anything. I second taking that truck to a scale. NEVER depend on what a salesman tells you about ANYTHING.
    jj1 Thanks this.
  7. jj1
    jj1 Bobtail Member
    8
    ^ Was just thinking that, I should go all in and get CDL A. I'll still start with a B type vehicle but I'll always have a choice to move up if I wanted to down the road--no pun intended.
