Find gear ratio on pete 389
Discussion in 'Peterbilt Forum' started by Wespipes, Aug 30, 2020.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,815
    Jul 14, 2019
    2019 pete 389. I was told its 3.25. I cant find it anywhere on the truck. Not in the glove box. Not on the door. I goggled and somewhere said to crawl under your rear end it should be stamped there. That says 416. Nothing else stamped anywhere. Any idea? If not ill call pete tomorrow and try to find out with my Vin. Also saw someone say you can tell by your rpms? I'm at 1350/1400 in 18th gear going 70 20200830_173950.jpg
    KB3MMX Thanks this.
  3. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
  4. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    What size rubber you running.?
    41" is tall 22.5" or low pro 24.5"
    KB3MMX and Wespipes Thank this.
  5. Wespipes
    1,037
    1,815
    Jul 14, 2019
    I'm running tall 24.5's
    singlescrewshaker Thanks this.
  6. Wespipes
    1,037
    1,815
    Jul 14, 2019
    Tire hight is 44
  7. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    I put 43" in one because usually an inch of tire height is lost in my experience from the weight of the truck squishing them down. If you can narrow down the rpm to 1350 or 1400 you can get a closer idea of which ratio is actually correct. As long as the clutch is not slipping rpm should be constant per given road speed. Spicer gear ratio calculator in Google is where I entered these values..
    Screenshot_20200830-193744_Samsung Internet.jpg Screenshot_20200830-193600_Samsung Internet.jpg Screenshot_20200830-193535_Samsung Internet.jpg
    Wespipes Thanks this.
  8. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Whats the last 6 of the vin? There should be a tag on the front of the pumpkin, may be covered in paint
  9. Wespipes
    1,037
    1,815
    Jul 14, 2019
    There is a tag. Covered in paint. I couldn't see any markings on it though
  10. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Get a rag with thinner and wipe it down.
    If you can't read that one do the same with the other rear.
    Sometimes a soft wire brush helps.
  11. Wespipes
    1,037
    1,815
    Jul 14, 2019
    Well peterbilt HQ was surprisingly unhelpful. I'll try a dealership. I suppose
