Fifth wheel wrecker
Discussion in 'Trucker Forum Classifieds & Trading Post' started by Acm, Feb 28, 2013.
  1. Acm
    Acm Bobtail Member
    20
    5
    Feb 28, 2013
    Getting out of trucking and towing,and have a heavy under lift for sale.it is a quick tach unit.the only things you need on tractor is a slider fifth wheel and 12 volts as hyd are self contained.it is an extremely heavy built unit,with 45000 lb lift rating retracted,32000 lb lift extended.comes with,short med and tall forks,wheel grids,straps,and 90000 lb safety chains.works really well with 265 wheelbase but I have used it on 220 wheelbase as well.tow your own,swapping out breakdowns or just getting cold gelled trucks into shop.once you run the wires,it takes only a few minutes to install and remove.located in mn.507-822-2552 can email pics if interested.
  3. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Is it the under reach unit ? Sounds like it .
  4. Acm
    Acm Bobtail Member
    20
    5
    Feb 28, 2013
    Yes it is an under lift.wheel lift with the grids,or frame or axle lift with the forks.can also sling tow off the bar if the axle of towed unit is damaged or missing.
  5. Acm
    Acm Bobtail Member
    20
    5
    Feb 28, 2013
    If you are interested pm me with your email,can send pics and price.thanks
  6. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
  7. fetch
    fetch Bobtail Member
    11
    Feb 27, 2013
    Manitoba
  8. Acm
    Acm Bobtail Member
    20
    5
    Feb 28, 2013
    In response to the last couple messages,it is avail yet,just send me an email and can send pics and info,thanks.
  9. bally64
    bally64 Bobtail Member
    Oct 18, 2012
    Hello ,do you still have it ?
  10. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
