Fifth Wheel Won't Lock?
Discussion in 'Experienced Truckers' Advice' started by trentmeseroll, Nov 27, 2016.
  1. trentmeseroll
    trentmeseroll Bobtail Member
    7
    I went to drop an empty trailer, pulled the fifth wheel release & pulled away. When I backed under my new trailer & the locking jaws won't lock around the kingpin. Please help. Thank you!
  3. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    are you sure you didn't back into it with it closed? what make is it wedge tail, clamshell, jost, k-hitch etc
    trentmeseroll Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I had a light weight Fontaine once. If the ground wasn't perfectly level it wouldn't hook. Also after sliding several trailers on and off, debris, dirt, grease would fall into the jaw area and keep it from closing, just had to scoop out some of the crap once in a while and it would work fine.
    Getsinyourblood and trentmeseroll Thank this.
  5. ryanbob1
    121
    35
    Sep 9, 2016
    yeah the wedge tails are like that sometimes they get too much grease wash it out with a high pressure cleaner and all good
  6. Boattlebot
    Boattlebot Road Train Member
    1,666
    21,079
    Aug 7, 2016
    Could be out of adjustment too. that happend to me a few times. couldn't bang trailers and shop turned a big nut on the side and no more issues.
    I tried to see what bolt it was so I could do it myself if needed but no luck.
    Dave_in_AZ and trentmeseroll Thank this.
  7. trentmeseroll
    7
    TY everyone. I drive a 15 Freightliner Cascadia I just pulled the release handle like I've done a ton of times to unhook & normally when I go to hook it closes but it's stuck open, handle out.
  8. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    Pull out from your trailer so you can see the jaws, are they in the open
    position? If they are closed you will have to stick a bar down in there and
    reopen the jaws. If the jaws are open than the handle might be sticking.
    Try backing under your trailer against the fifth wheel and jiggle the handle.
    Make sure the handle mechanism on the front under side of the fifth
    wheel is lubricated. Sometimes that linkage will get so dry and rusty the
    fifth wheel will not latch properly. Buy an aerosol can of "white lithium"
    grease. That will spray several feet, you should be able to spray that
    linkage area and hopefully free it up a little.
    If you get the fifth wheel to latch, stick your head under the trailer
    and look at the back side of the fifth wheel to verify the jaws have in
    in fact closed properly. Good luck.
  9. MACK E-6
    48,131
    219,684
    That sounds like someone tightened the jaws to stop backslap on an older trailer with a worn kingpin, so when he went to hook up to a newer trailer you couldn't get latched.
    Lepton1, Dave_in_AZ and trentmeseroll Thank this.
  10. rcelmo
    459
    1,986
    Mar 23, 2015
    I am sure you already checked this but is there a space between the fifth
    wheel and the trailer. If the trailer is jacked up to high it will likely not
    latch. Are you on uneven ground? Are the truck tires in a hole causing the
    truck to be tilted one way while the trailer is tilted the other way? If this is
    the case try coming under the trailer at a bit of an angle. This is a little tricky
    to do, make sure you get out and look to be sure you are lining up with the
    pin properly before you back up all the way.
    Again, good luck. Be patient and keep trying.
    starmac and trentmeseroll Thank this.
