Fifth Wheel Won't Latch Onto Trailer
Discussion in 'Experienced Truckers' Advice' started by tscottme, Feb 17, 2012.
  1. tscottme
    tscottme Road Train Member
    Infrequently I've had this problem. It always happens after I try to back under a trailer that has been left too high (landing gear left too tall).
    When this happens, everything looks normal: trailer sitting evenly on 5th wheel, 5th wheel release handle in, 5th wheel jaws closed around kingpin. However, when I pull against the trailer (tug test) the trailer slides off the 5th wheel as smoothly as when I'm dropping the trailer.
    Here's the fix the mechanics showed me, much easier and cleaner than my old fix. Pull and hold the 5th wheel release handle for 5 seconds. During this time the jaws will slowly slide open and the lock mechanism resets. Now when I back under the jaws close and I hear the "click" sound as normal.
    My old method was to have someone try to pull the 5th wheel jaws open as I pulled the 5th wheel release handle.
    I've never had the "pull and hold" method fail to fix the 5th wheel won't latch condition.
    Lastly, ALWAYS DROP YOUR TRAILER HANDLE WHEN DROPPING A TRAILER. Don't leave it sticking out from the trailer, it will bent or broken and the next driver will be screwed.
    allniter, jimvrg and davetiow Thank this.
  3. walstib
    walstib Darkstar
    Why not lower the gear?...I always back up until I've covered 1/2 of the 2nd set of drives then get out and look...I got in this habit after my very first hook and the trailer was so high, it got caught in FRONT of the 5th wheel...Very embarrassing and I said, never again...
    davetiow, Raiderfanatic and 70s_driver Thank this.
  4. andy
    andy Light Load Member
    213
    72
    Oct 16, 2010
    MT
    Haha I'd like to see that done.
  5. haulhand
    haulhand Road Train Member
    I used to "pick" a fifth wheel multiple times a day with a bar. The truck I was driving had a fifth wheel that flipped upside down into a hole to be hidden out of the way and if you didn't latch it before you flipped it the handle would ge bent. On topic depending on what model fifth wheel you have this method won't always work. If you have a decent holland that has a handle and an adjustment pin that stay out when the handle is pulled they won't reset themselves, but if you take a bar and hit the jaws from the front towards the back they will open.
  6. camaron32
    camaron32 Light Load Member
    81
    6
    May 31, 2010
    Rosemount, Minnesota
    Yeah, I've had it happen before where I missed the kingpin and it was on the front side of the fifth wheel. Not hard to fix, just a PIA. As for the problem with the fifth wheel, I would insist that they either repair it or have the fifth wheel replaced. I envision the trailer seperating from the cab as you drive down the road. A problem I wouldn't wish on my worst enemy. Remember, if something happens it's on you.
  7. monday1313
    monday1313 Bobtail Member
    Thanks for saving my bacon!!!!
  8. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    yea that's what Id always do with all trailers I pick up unless they were already low. Id back up under the trailer until the fifth wheel was about to go up under the trailer. Then go back and let the trailer down enough to where when I backed under it, it would lift the trailer up a little so that when I did hook if it was off centered a little, the trailer would move whichever way it needed to without dragging the landing gear on the pavement or whatever. Im sure you've picked up trailers where the landing gear was hard to roll up? That's why, because someone has slid the trailer when they backed up under it and drug the landing gear on the pavement. It bends a little and makes it hard to roll them up. I never did that if the trailer was leaning downhill though, just when it was sitting flat level.
  9. Mountain Hummingbird
    Mountain Hummingbird Medium Load Member
    601
    399
    Oct 14, 2012
    Different trucks have different 5th wheel heights, back up so that you can see the height of the trailer lower the trailer so that your 5th wheel will pick it up, let the air out of your drives back under then refill your airbags. lifts the trailer up. As far as the 5th wheel not latching properly time for a good cleaning, grease job and adjustment .
    davetiow Thanks this.
  10. ncmickey
    ncmickey Road Train Member
    3,820
    7,106
    Jun 21, 2013
    Durham NC
    I've had just the opposite happen. I pull the handle to unlock, get back in truck, put into gear and the handle unlatches and relocks the 5th wheel. Then get back out, pull handle till it locks, get back in and release brake.... and,handle slips back in.
  11. Dima01
    Dima01 Bobtail Member
    Thanks for the tip. I will try it tonight.
