Fifth wheel rebuild
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Feb 1, 2019.
  1. insanityeight
    insanityeight Light Load Member
    287
    111
    Jul 26, 2013
    birmingham al
    At 500,000 miles fifth wheel is adjusted all it will. Can i get away with lock and jaw rebuild kit or do i need complete rebuild kit for twice the money
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    What 5th wheel do you have?
    Wannabe tech Thanks this.
  4. insanityeight
    287
    111
    Jul 26, 2013
    birmingham al
    Not sure of model but its a holland with the 3 notch adjustment on top of plate
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Throw it in the scrap bin and buy a Jost top plate.
    Every rebuild of every other plate will never last as long as the original due to wear of the plate itself. Some that are badly worn can be close to max adjust right after rebuild depending on the model and how hard it it used.
    I inspect the plate for shrooming and excess wear before building. If it's badly worn with sharp edges , just replace it.
  6. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    Thanks. Never did that model of 5th wheel and did not know a Jost would go on it.
    Also consider the liability of rebuilding them.
  7. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    If the top plate is in good condition there’s nothing wrong with using a rebuild kit.
  8. insanityeight
    287
    111
    Jul 26, 2013
    birmingham al
    Thanks. Thats what i figured. Guess ill do the lock and jaw kit
    boneebone Thanks this.
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    "If".
    9 out of 10 I see are dropped and hooked so often and slammed so hard the plates are garbage. That's the nice thing about a Jost. Replaceable throat.
    blacklabel and daf105paccar Thank this.
  10. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    bought a jost fifth wheel two years ago. after putting it on the handle would come back out when pulled test after hooking up to trailer. told the dealer about it he sent a mechanic out to look at it. they called jost they didn't know why it would do it. so we pulled it an put another one on an it did the same thing . I made them take it off an put on a fontain fifth wheel on . I did not want to risk dropping a trailer going down the road an killing someone. the dealer told me that jost sent them rebuild kits for them an they still did it. they sent them back to jost they never heard what they found out.
  11. Rideandrepair
    17,202
    55,792
    Aug 8, 2015
    My Holland is out of adjustment. It has the bolt in front.backed off all the way, still sloppy.Rebuild kits around $500 looks like a simple job.It seems like a very simple design, compared to others.Anything I need to know, before tearing into it?
