Fifth wheel play on slider
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dallas05, Jan 11, 2022.
  1. Dallas05
    Dallas05 Bobtail Member
    Hello y’all,
    Have a question regarding my fifth wheel. Today after hooking up to my trailer I notice that when I accelerate & let of the gas my trailer would slap back & forth. I notice that my fifth wheel would rock back & forth about less then half an inch on the slider. The fifth wheel lock pin is fully out locked on the slider teeth. I was told by a driver that my slider needs lubed so that the fith wheel would rock back forth smoothly not hitting slider end rough. Has anyone dealt with this?
  3. Dale thompson
    5,103
    42,263
    Nov 20, 2013
    commerce twp,mi
    There is 3 points of contact 1 lock jaws of the 5th wheel (adjustment) 2 5th wheel to slider (pins and bushings) 3 slider lock mechanism can be worn and need adjustments or new parts.
  4. noworrez
    noworrez Light Load Member
    97
    142
    Aug 6, 2020
    What @Dale thompson said, if you don't have the adjustments to tighten it up with no sliding back and forth, time to either rebuild the top plate or replace it. I had the same problem this summer and rebuilt mine, now it's nice and tight. The most difficult of the endevour was lifting that heavy pig off and back on by myself, had a flat cart with wheels, got it flipped over then used a come along.
  5. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    I just flip my Hollands over and rebuild them right on the frame of the truck.
    noworrez Thanks this.
  6. Lazer
    Lazer Road Train Member
    1,729
    2,730
    Jan 22, 2017
    Depending on the brand/style of 5th wheel, they can be adjusted, to reduce-eliminate the sloppyness. Years ago, Fauntains(sp) were the easiest to adjust.
  7. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    If its an older trailer that stays wet and has seen a lot of salt and metal cancer causing chemicals check the king pin and bolster plate. Loose king pin due to rusty bolster well also cause the movement you described. Flat beds and reefers tend to get it worse than dry vans cause water and crap gets in easier from the top of deck floor. Thats why some are built with a bolt on easy to replace bolster.
    Deezl Smoke Thanks this.
  8. buddynewOO
    buddynewOO Bobtail Member
    47
    21
    Aug 10, 2020
    MN
    I am going to be attempting this on my own in my driveway replacing a stationary with a slider. I have the slider on the back already so think in can maneuver it in place I am going to unbolt old one and try to slide it off and onto a 4 wheeler.
