Fifth wheel placement on a long WB tractor
Discussion in 'Heavy Haul Trucking Forum' started by Macneil, Aug 27, 2019.
  1. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    This question is probably easily answered by some, so here I am asking.
    Up here in the north (Canada), you don’t see many stretched tractors unless they are tri drive or tandem with an air lift. I’ve pulled lowboy/float with a 4 axle (tandem with air lift) before and never had issues. Here’s where my stupid truck comes in. It’s a 275” WB W900L. 16k front, 46k rears. It’s been stretched because come winter time, I pin up to a quick swap (think heavy wrecker business end). Now I know a long nose is hard to get weight up to the front and even harder with it being stretched.
    Here comes my question..
    How far forward (over Center of the drive axles) is it advisable to slide the 5th wheel? Because I use a quickswap, I’ve got enough slide rail to put it in the bunk if I wanted to. I just got the truck a few months ago and while I don’t haul gross weight every day, making it to a scale with a heavy load is few and far between.
    I have an overweight permit for non divisible loads which allows me to put 14.6k lbs on the steer (smaller tires up front so I can steer in the winter and not float around) and 46k on the drives. The wagon I’m allowed roughly 67,000 k on the tridem.
    I tare out at 12.7 steer, 24k drives and 17.2 on the tridem out back.
    Typically with a 40-50k lbs payload shoved to the back my steer weight will only change 40-50 lbs. I’ve never been over on the drives and with that little payload I wasn’t concerned about the wagon.
    Fast forward to the last few weeks where I’ve been in the Bush hauling heavy and I’ve noticed that my drives are a bit heavy and my steering is a bit lighter. Now fast forward to today and I had a 74,000 lbs nodwell to bring back into town. I finally was able to get to a scale and my steer was 12.5 k lbs, drives were 46,860 k lbs (front drive was a touch heavier than the rear drive, which put me over my 46k allowable and I was slightly under on the rear drive) and my tridem was bang on at 66 k lbs and change.
    Tonight when I unloaded and did all my post trip, I slid the fifth wheel a few notches forward but as I said before, how far more forward past the Center of the drives is too far? I jackknifed to make sure I had all the clearance and I’m still ok.
    I know this sounds pretty simple and it should be but maybe I’m just over looking things. 99% of the time, on any tandem I’ve ever pulled the 5th wheel is #### near bang on between the drives. Just don’t want to be way over on my front drive and not heavy enough on the rear.
    Come winter time, having that extra steer weight will be nice regardless.
    Thanks in advance fellas.
    jamespmack Thanks this.
  3. Macneil
    711
    426
    Dec 15, 2010
    I forgot to ad something!
    I’ve got a two pin placement for king pin on that wagon also. I’ve never measured the current hole but let’s assume it’s around 30-36”. The first hole looks to be about 12.
    4mer trucker Thanks this.
  4. 201
    201 Road Train Member
    12,058
    24,619
    Apr 16, 2014
    high plains colorado
    Good luck getting legal with any long wheelbase truck.
    Bean Jr. Thanks this.
  5. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    I would suggest trying to move the 5th plate forward 5 pins if you can, or more. But not sure where your load was centered I don't think you will be able to keep drives legal. With that heavy load unless you reverse the way you loaded it next time???
  6. Macneil
    711
    426
    Dec 15, 2010
    I was thinking of doing the load reversal but when I was looking at the machine, it’s pretty evenly balanced from what I could tell but it would be worth trying.
    I had it shoved to as far back as I could put it to get those weights. I think I slid it forward 3-4 slots. I’ll have to count tomorrow.
    Intothesunset Thanks this.
  7. Macneil
    711
    426
    Dec 15, 2010
    Said boat anchor from scale ticket today.
    booley Thanks this.
  8. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Oh. You may never get your drives legal.
    What are you legal for on drives? 34k? I think you had to much weight for a tandem drive. You may need a stearable, or pusher for that much drive weight.
    201 Thanks this.
  9. Macneil
    711
    426
    Dec 15, 2010
    I’m good for 46k on non divisible loads such as this one. We have 8 axle set ups however I was the dude with the load at the time. For future, we now know that those are too heavy for me but I’d like to get the steer axle a little heavier without causing too many headaches(drivability) on my drives.
  10. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    What is too heavy for you 8 axles??
  11. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Just slide your fifth wheel up 3-4 notches and try that. Ideally you will want max steer axle wieght when your at max drive axle wieght. Full fuel of course. Then that's your happy spot.
    Just keep on sliding it up till you achieve this. As long as clearance is a non issue.
    beastr123, Snow Monster and AModelCat Thank this.
