Fifth wheel height for pulling tanker?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by me myself and I, Oct 5, 2018.
  1. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    Whats the best height for pulling tank?
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    The standard height. But it depends on operation also.
    For some reason. ON mine. If I'm lighter. The truck is heavier. When I"m fully grossed for the load I haul. The trailer is heavier. I can haul 97k. But the loads I currently haul only come in at 90 - 92. The trailer is 2k heavier.
    About 85 makes both axles even. Less and the truck is heavier. The load i can get 97 with. Has no scale so I have no idea on those numbers between the 2 axles.
    My drives and drop are 22 tires. The rest are 24.
    You guys that have the same size tires. Might have a different scenario then how mine plays.
  4. Ruthless
    Ruthless Road Train Member
    8,802
    86,199
    Aug 28, 2010
    The City.
    Tire size on the tank, rear discharge vs center discharge, single compartment or multiple- is imagine these all factor in.
    @Cat sdp
  5. BKLusk64
    BKLusk64 Light Load Member
    106
    59
    Nov 17, 2012
    What is stanards height???
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Center drop (double conical) or propane tank you kinda want to be level.....
    Everything else the higher the fifth wheel the better........
    I got 24.5 talls and like 3-4 inch legs on the 5 th wheel. I’m not sure what it measures tho.
    Ruthless Thanks this.
  7. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    42”
  8. Ruthless
    8,802
    86,199
    Aug 28, 2010
    The City.
    Thatd be very low. Box trailers that are 110” inside height require 47.5” fifth wheel height.
    I glide 47 and slim shady Thank this.
  9. Jazz1
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    I don't like cranking dollies. Lower landing gear 2" from the ground and dump your air. Nothing more aggravating than having to lower a loaded trailer 5" because billy big rigger dropped trailer landing gear to the ground and continued cranking a few more inches.
  10. Ruthless
    8,802
    86,199
    Aug 28, 2010
    The City.
    Soooooo..... are you sticking with your claim that fifth wheel heights for tankers are 42”?
    I don’t pull tankers. My fifth wheels on both my trucks are 54” top plate height. They are higher than most: but not by a foot.
  11. kemosabi49
    10,442
    44,426
    Jan 13, 2013
    SW Arkansas
    My fifth wheel was around 49". With tall 24.5s, it raised the trailer enough to unload the rear dump trailers without being so high to transfer too much weight to the rear.
