Fender mirror won't stay in place
Discussion in 'Trucks [ Eighteen Wheelers ]' started by majestyk, Jun 27, 2010.
  1. majestyk
    majestyk Road Train Member
    1,658
    885
    Jun 28, 2009
    las vegas, nv
    Thought it might be a problem with the old fender mirror so I put on a new one and now it is having the same problem. The mirror will not stay in place. Any good suggestions on what to use to stabilize it without immobilizing it in place permanently.
  3. johnday
    johnday Road Train Member
    Tighten it up? Sorry, couldn't contain myself. Try a little LocTite on the hardware. BTW, what's moving on you?:biggrin_25525:
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Is it the shaft it's mounted to that's turning (like mine does), or is it the mirror itself turning on the ball mount?
    I had one side that just the mirror was turning and tightening the three screws on the mirror itself solved the problem. The other side however, the tube that adjusts the bracket length has a slip-nut on it and it doesn't stay tight for very long. I thought about jb-welding the thing in place once the mirror is adjusted. It drives me nuts...:biggrin_25526:
  5. wiseguy3501
    wiseguy3501 Light Load Member
    247
    40
    Mar 3, 2009
    Lakeville, MN
    Superglue the sucker....once its adjusted correctly, it doesn't matter if its superglued. Won't be moving anytime soon. When I was younger I had a sound system in a car where the mirror would end up pointing directly down in a matter of two hits from the subs, superglued the mirror, and it was all good.
  6. Hubcap
    Hubcap Medium Load Member
    547
    1,547
    Dec 29, 2009
    Rhome Texas
    Put some silicone in the mirror ball joint after loosening the screws up a little. let it set up before you tighten it down again. That will give it a softer surface to seat itself to.
    As a speaker reconer, I also know that superglue will get brittle with sunlight and age. When I was in that business, I wouldn't use superglue not because it didn't work, but because it wouldn't last. Most of my fellow reconers thought that it was a way to insure business traffic.
    Epoxy will last much longer that superglue.
  7. majestyk
    1,658
    885
    Jun 28, 2009
    las vegas, nv
    thanks guys I will give it a shot. it is the actual mirror rotating around the ball joint not the bolt being loose that is causing the problem.
  8. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,712
    Jul 1, 2009
    Springfield,MO
    LOCKTITE! That's what it's made for! Use the right tool for the job!
  9. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    I suggest instead of making it inservicable on the nuts you get some nylon type lock nuts. A favorite item on all my repairs. They are vibration proof.
  10. lilillill
    5,642
    13,470
    Nov 7, 2007
    Then tightening the three screws should cure it... along with maybe a dab of superglue or locktite in the ball joint itself once the mirror is adjusted correctly.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Yes, tighten the 3 phillips head screws up around the ball joint. It'll put more pressure on it locking it down. You shouldn't need any glue on a new mirror.
