Fedex ground road test
Discussion in 'LTL and Local Delivery Trucking Forum' started by PALOU, Aug 14, 2014.
  1. PALOU
    PALOU Light Load Member
    215
    28
    Dec 16, 2013
    OTR
    Hey every fedex driver,have road test coming ...what to expect ?
    any infos would be appreciated
    thkx
  3. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    Not sure if required but they may want you to flip one over. Sure see lots of them that way-especially in winter. Have no idea. But just relax and drive. Thorough pretrip and you'll be fine.
    ryan5464, OPUS 7, PALOU and 2 others Thank this.
  4. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    If he can flip one in the summer, he'll be perfect for winter time Great Lakes region driving!
    Big Duker Thanks this.
  5. Radman
    Radman Road Train Member
    2,034
    2,454
    Apr 18, 2011
    Hook to a set and drive around the block. That's what I did.
  6. PALOU
    215
    28
    Dec 16, 2013
    OTR
    what if you never hook doubles before? are they doing it for you and you just drive?
  7. Radman
    2,034
    2,454
    Apr 18, 2011
    Yup, or help you hook a set. But you'll drive it around probably the yard first then on the street. I did it never driving a set of doubles. Drove it on the street. He'll instruct you let you know how it'll handles and turn. Just drive it like your pulling your 53" the back trailer will follow. No sweat. If you can drive the 53" this will be cake.
    OPUS 7 Thanks this.
  8. PALOU
    215
    28
    Dec 16, 2013
    OTR
    thkx for the infos man....will try it
  9. moloko
    moloko Road Train Member
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    Hooking up to doubles is the same as any trailer. They are a little wobbly when empty but turn easier than a 53' trailer. They have a break in the middle so you don't need to swing as wide with doubles. Take your turns 5 mph slower than normal and make no sudden jerky movements with the wheel while changing lanes , to avoid the crack the whip effect. Lastly, don't panic. There's nothing to it.
    OPUS 7 and PALOU Thank this.
  10. OPUS 7
    OPUS 7 Road Train Member
    1,124
    1,010
    Aug 13, 2010
    404
    I got paperwork one day for a set.A guy helped me hook up,and I was kicked out of the nest.
    It wasn't that bad,then got another set coming back home :biggrin_25519:
    dennisroc Thanks this.
