Fellow truckers after pulling 53 for 2 years decided to do fedex double.. I would take any advice.. thanks
Fedex double
Discussion in 'Questions From New Drivers' started by vastoka, May 30, 2022.
I pull doubles for Fedex also, first is double check your connections. Both hooking and unhooking. People rip there air lines off getting into a hurry unhooking.
Another would be teach yourself how to back a dolly using your mirrors. When it rains or snows the back window gets filthy and a lot of people struggle spotting their dolly.tscottme, austinmike, Lumper Humper and 1 other person Thank this. -
1. don't go anywhere where you have to back up
2. Carry brake or contact cleaner.. it will remove the gobs of grease you will find everywhere. -
Some guys told me don’t have to do wide turnes, is that right??
austinmike Thanks this. -
they do turn better then a 53’vastoka Thanks this. -
Doubles (wiggle wagon) easy on the corners, catch my drift. Heavier box in the front.
When pulling doubles, go around corners like you only have the lead trailer behind you. Having pulled 53 ft trailers for so long your tendency will be to take corners much much wider because the combo is longer with 2 pup trailers. This will put the rear trailer over into the lane opposite the corner. For example if you are trying to swing to park or travel through a pull-thru parking spot, and you don't ignore the rear trailer as you should, you will swing far too wide and your rear trailer will not go through that pull-thru. It will hit the whatever is parked on the outside of your curve. The second trailer will go wherever the first trailer goes. It might off-track by an inch or two, at most.
All of the air valves between the tractor and the front of the rear trailer need to be open. There are valves at the back of the lead trailer (open them). There are valves in the converter dolly (open them). There are valves at the rear of the rear trailer (close them). When you are driving and apply brakes, there is a short delay between pressing the brake pedal and the brakes on combo taking affect. The rear trailer brakes come on first, and it's very easy to lock up a set of brakes in the combo. Drive like you are on ice, until you get used to it. If you see anything developing that MIGHT make you brake, let off the fuel early and let weight of the combo start to slow you down. When applying brake apply early and lightly. PANIC BRAKING is to be avoided ans one axle will likely lock and then skid. The main thing is corner like you are only pulling that lead trailer. I mean that literally.
