Fault code 3375 on my Cummins isx15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Black Panther 4114, Nov 25, 2018.
  1. Black Panther 4114
    Black Panther 4114 Bobtail Member
    Turned truck off for 10 hour break it was fine turned back on now my oil pressure gauge is stuck at 100 and I'm getting a fault code 3375. Has Anyone had this problem?
  3. Ridgeline
    22,108
    113,239
    after-treatment diesel particulate filter - that's all I have.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    3375 is dpf regenerations occurring to frequently. Not related to engine oil pressure as that would be a separate issue.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Clean injector 7, replace it is the real thing to do. Probably full of carbon not letting regen to happen properly. Search YouTube for rawze videos, he has lots of excellent information for keeping these engines healthy. He works on a cm871, but the same theory applies to later cm2250, cm2350, and x15 engines. It is called egr tuneup I think. Series of 6. Must watch.
  6. DYLAN_131
    DYLAN_131 Light Load Member
    136
    131
    Nov 21, 2018
    After researching your fault code with all my diag and dealer software, 3375 has to do with your after-treatment system, more specifically your DPF. Common causes for this code are: 1) DPF differential pressure sensor failure 2) Fuel rail pressure relief valve failure 3) Loose injector high-pressure connector 4) After-treatment DPF failure 5) ECM calibration.
    I hope this helps.
  7. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,568
    Dec 30, 2017
    Coal Town
    Welp there goes about $10,000 down the drain with Labor cost...
  8. DYLAN_131
    136
    131
    Nov 21, 2018
    Depending on the labor rate of the shop, you arent too far off. If I had the year if the engine in question, I could give an exact amount of labor hours according to my software that uses the dealer "book" times.
