i need the full scoop on this:
http://www.fastertruck.com/
i'm not saying i would use it; i'm just curious about it.
FasterTruck:
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Jun 7, 2010.
Page 1 of 3
Hmmm, looks like a good idea.
I'd be interested too. -
I know a bloke who has one of these set ups, full of praise for it , works well
This works by blocking the speed sensor's communication with the truck's computer, which essentially renders your speedometer useless. How are you going to explain that speeding ticket you just got? Is that worth losing your job? Also, another potential problem is if the odometer does not continue clicking over the miles it should. The truck computer will report a significant loss in the mpg department, and you are nuts if you don't think that will raise red flags at the company...possibly leaving you sitting at a shop until they figure out WHY the truck is getting such poor fuel mileage (or until you fess up, at which point you will be fired). Then there is the fuel tax issue. If the truck is not keeping track of miles accurately, mileage may not be reported to the states accurately, which if discovered could be used as evidence against the carrier (and you) when the government starts charging people with tax evasion.
Sure, it will let you drive faster...just like your truck isn't governed at all...but WHEN you are caught, good luck finding a job. If you don't think tampering with the truck in that manner will show up on your DAC in a way that will keep most other companies from even considering you, you are nuts.
If you want to drive the speed limit, don't work for companies that put you in 62 mph trucks. It really is that simple. You know what those companies are, and if not, ask what the trucks are set at. If you don't like what they tell you, thank them and tell them to call you when they turn 'em up to run the speed limit. You have a choice in who you drive for.....use it.Saddle Tramp, FriedTater and KWhoppert600 Thank this. -
But then again, you probably wouldn't know that. -
......sooooooo, it does work?
One thing i don't quite get is they are saying the speedo still works just not exactly at the same level when you have the device turned on? Or something like that. -
This device works by intercepting the signal between the speed sensor and truck ECU, sending the signal to the ECU saying the truck is still operating below the governed speed. So, if your truck is governed at 62 mph and you have this device set to work at 60 mph, the speedometer will read 60 mph no matter how fast you are going, and the miles on the odometer will click over as though you are going 60 mph no matter how fast you are actually going.
The speed leads to the potential for speeding tickets. The odometer leads to your getting caught when the fuel mileage numbers don't add up, and also leads to the potential for fuel tax evasion charges if the company ever gets audited and they determine that you are the one that altered the truck to show less mileage than you actually traveled. -
you can keep track of your speed with a gps
the odometer doesn't care whether you go 60 or 70 , the miles are the same -
300.00 seems to be a bit much. I run 65 all the time, the truck will do 73. I only bump it up pass 65 when I come to some one running 64ish. I hate when JB Hunt and Swift do the snail races. 4 wheelers start passing on the shoulder. This would be the ideal time for it, pass and then turn it off. My odometer stopped working years ago. I track mpg and oil changes on paper with gps and google maps.
Page 1 of 3
