FASS or AIRDOG
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Sep 11, 2011.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    Hi,what from the 2 is better,fass or airdog.what not have troubles and bring more for the engine
  3. rollin coal
    rollin coal Road Train Member
    13,280
    26,782
    Mar 29, 2008
    TN
    Either one will work fine. Which one is cheaper? Airdog and fass are competitors one is owned by a father, the other owned by the son. There's been lots of legal trouble and court battles between them. Both products are good..
    areelius Thanks this.
  4. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    I would prefer airdog. This is for pickups not sure how big trucks work. The FASS replaces the factory fuel pump where as the airdog is just an additional pump so if the factory goes out the airdog will still run it and if the airdog goes out the factory can still run.
  5. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I have a FASS on my C15 Acert. I am happy with it.
  6. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    How run you engine with the fass,have you a better mpg
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I saw FASS on Volvo FH12. stock fuel pump was disabled, but there was one problem with Volvo. It is related with ECM cooling. stock pump "sucks" fuel through ECM cooling plate, so it is designed for negative pressure. FASS is the electric pump with good output, pressure is limited with engine fuel pressure limiting valve, and it is 4 BAR calibrated on D12 engine so if you install FASS before ECM it will damage ECM... easily) I used to fix some ECMs. Some were junk.
  8. Riverstick
    Riverstick Light Load Member
    186
    41
    Aug 26, 2011
    Ireland
    Did it improve performance/milage on the D12 engine?
  9. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,184
    Aug 20, 2009
    I talked to the "Dad" company at MATS last year. He was quite informative. Told him I had a light on the dash of my Century Class that said "Fuel Prorater" or something like that. Told me that was his system.
    Not meaning to hijack your thread, but anyone use the Turbo 300D?
  10. rollin coal
    13,280
    26,782
    Mar 29, 2008
    TN
  11. raf147
    raf147 Bobtail Member
    43
    7
    Feb 20, 2011
    Wheeling, il
    What is the main difference between the two? I'm also looking to buy one, but I can't decide. Air Dog is better choice for regular pick up trucks, at last that's what they voting for on other forums, can't find much for big trucks. Air Dog is also more expensive, for C15 it cost around 1,600 + for 260GHP, FASS system is much cheaper, something around 850 + fuel line kit.
    I have not called either company to find out what is the real difference between two if any, can someone here let us know... Thanks.
