Fan cooling
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lovesthedrive, Jun 24, 2011.
  1. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    I know cars have gone to more efficient cooling with an electric fan. Why not trucks? Is it because there are no fans rated for the CFM needed by a truck? I think it would be a better way to keep the truck coolant at proper temp than trying to swing that giant propellor under the hood.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    car electric fan is 200 Wt maximum, and not so small, it is not enought for class 8 truck. Wanna save some fuel (1-3%) - switch to BW two speed fan, like used on Mercedes Actros ore electro-hydrolic fan clutch like on MAN TGA (PWM controlled), bit IMO, you will not save more 3% fuel.
    As a good advice of electric fan use is to get fan for example from Audi A6 ore from Taurus and disable lining fan clutch with A/C (reprogramming ECM).
    I did this way - if you turn A/C on lining fan is off, but electric fan runs at low speed, when lining fan is on, electric fan runs on full speed. We did this conversion on KW, I used '94 Ford Taurus relay with '99 Audi A6 fans (dual fan).
    May be it does not save a lot of fuel, but saves lining fan clutch and beltd drive
  4. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    When the fan is running mechanical is more efficient, only problem is they usually take some power when they are not used. You are right, there is no electric fans big enough and they would need a very big alternator. Biggest mechanical fans need about 75 hp at max rpm, that's about 55 kW, you can calculate how many amps is needed at 12 volts..
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    55 000/12= 4583A
    OMG! wires of elephant's leg thik!
  6. lovesthedrive
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    but you dont need fan at max. At max you are going down the road and the air in front of truck is flowing through. The only time you need the fan is stationary or low speeds when your air flow is not optimum.
    The electric fan is ideal for cold weather.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I concider that factory ECM programming when cooling fan is on every tome you turn A/c on is not optimal, becouse air flow is exessive!
    That's why we used to add electric cooling fans to use with A/C only.
    150-200 WT is more then enought for A/C condencer and no reason to use BIG LINING FAN.
  8. texas rattler
    texas rattler Light Load Member
    76
    13
    Aug 7, 2011
    cat spring texas
    i just looked at a 379 pete with 4 electric fans and the mechanical removed he has all 4 wired to the switch on dash. anyone seen this before? i checked the air clutch and it works ,never seen this before
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    as a good solution I'd prefere BW twin speed fans, like on Actros. ore PWM controlled MAN TGA fan...
    unfortunatly US truck maker do not use this kind of fans.
  10. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    I saw it on a 99' 379 Peterbilt that a friend used to own. Had its own dedicated switch on the dash.
    KH
  11. texas rattler
    76
    13
    Aug 7, 2011
    cat spring texas
    thats how this one is , i ended up buying the truck and will use a heavy duty relay that can handle the 4 fans. mainly because it will be a pain to remove them. i figure ill try it and see how well it works.
