Fan clutch thermal or air???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by flc120, Oct 26, 2012.
  1. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    well i just picked up a international 1990 eagle 9000 series truck it has a ntc350 cummins and i noticed it has a fan clutch which looks like one which would be found on a car, i looked everywhere and cannot find a air line going to it whatsoever.
    my question is is this a thermal type clutch which engages at a certaint temp or when AC is on? or they never made them like that on HD truck applications.
    please get back
  3. DieselDummy
    DieselDummy Light Load Member
    173
    62
    Apr 1, 2012
    Willet,NY
    works the same way as on a car, only ever seen them on the older cummins though
    CondoCruiser Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Question: How is it driven? By a water pump shaft too?
  5. DieselDummy
    173
    62
    Apr 1, 2012
    Willet,NY
    same way as on a car, temp rises in rad, internal clutch senses it and it locks up as an air clutch would.
  6. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Some of them have the air line routed up against the inside of the radiator core and connecting to the center of the fan hub (very hard to see, but you can feel it with your hand). If it's strictly thermal, it will sound like an airplane all the time and the fan will never stop completely.
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,420
    8,016
    Jul 11, 2012
    in the bush somewhere
    never seen that on an ntc cummins, only on a CH Mack with an E7 motor. but they really dont work or sound any different from an air ooperated fan
  8. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I know how they operate, just curious what it's connected to. Does the engine have the water pump in the front like a car?
  9. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    The water pump is in the front of an ntc Cummins but no way it could carry a fan, it's too low on the engine, so it would have an alternative style fan hub for the viscous fan drive to mount to and the fan.
  10. DieselDummy
    173
    62
    Apr 1, 2012
    Willet,NY
    Mounted the same way as a traditional fan would be, with fan shaft and bearings and drives off of crank. Will not sound any different than a traditional fan would, you just have no control over it.
  11. flc120
    916
    122
    Jul 11, 2012
    i figured i have no control over it, its definetly a thermal unit i guess it turns on when it feels lol.... it doesnt sound like its on all the time for sure.
    hey diesel dummy is the 87 9370 INT that you have a set back or forward axle truck im trying to figure out what model 90' eagle INT i have...
