Series 60 Detroit.
Truck off, key on, the fan should be able to spin freely, yes?
It does not....
Fan Clutch Question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thaistick, Mar 14, 2018.
Page 1 of 3
the fan system is electric over air and can be a normally open or normally closed and is computer controlled. -
No when you turn the engine off the fan engages that's normal
thaistick Thanks this. -
Sometimes with the truck off and key on I hear air hissing, not all the time...just trying to determine if I need to replace it. Fan does not stay on while running down the road, unless of course I it the override switch.
Like to know myself I have a 99 Sterling with a detroit 60 and the fan doesn't spin freely also but the fan runs all the time. Don't know if it's the over ride switch,solenoid,or clutch itself.
That it works when the switch is on would point to a problem outside of the clutch itself. Possibly a sensor or some other problem in the control side of the fan.
Bean Jr. Thanks this.
Page 1 of 3
