So I keep hearing guys say they will leave 1203 on if they go from gas to a full load of diesel.. But then if they load a full load of diesel a second time (diesel to diesel), they switch to 1993.
Yes, we all know if you have one compartment of 1203 and 4 compartments of 1993 you are supposed to placard for 1203 because you placard for the lowest flashpoint, so I’m not asking about that. I’m asking about full loads specifically.
I’ve been reading the Code of Federal Regulations and haven’t been able to find the answer..
The closest I’ve come is title 49, sub title B, chapter 1, sub chapter c, part 172, sub part F, 172.514
It talks about bulk packaging (tanker trucks), and how you have to be placarded when empty, the same as your last load... because of vapors.
But no where else in the CFR can I find and specific rules about flashpoint, or ANYTHING fuel related. Specifically about the 1203 to 1993 question.
Is this a state thing, rather than federal?
Anyone familiar with the CFR and know where to find this info?
Familiar with CFR? Placarding 1203 for a full load of 1993?
Discussion in 'Questions From New Drivers' started by chmpbt, Dec 13, 2017.
1203 is gasoline and 1993 is the generic placard for Flammable, each hazard class has a 'generic' number; 1993 is Flammable Liquid NOS [not otherwise specified] and with the US drifting slowly into international compliance.
Diesel used to be a 'combustible', a US term for liquids with a flashpoint of 101 degrees to 200 degrees [class 3 had decimals according to the flash point where gas was 3.1 and combustibles were 3.3; the rest of the world did not make this distinction so the US changed, little by little] and Flammable was reserved for products with a flash point under 100 degrees.
Looking now in 172.101 tables, I see that Diesel fuel does not have a specific number and Fuel oil [#1,#2.ETC.] is all placarded 1993tscottme Thanks this. -
At present, Flammables liquids are those with a flashpoint up to 140 degress. Combustibles are from 141 to 211 degrees. According to the hazmat chart Diesel is the same a heating oil, UN 1202.
RockinChair, beastr123 and tscottme Thank this. -
When hauling diesel, I keep a single compartment with gas tails (the little bit that won't drain completely) so I'm legal to placard 1203.
That said, when I have every compartment loaded with diesel, I placard 1993.
That's per my bol instructions for that product.
In speaking with a rack manager, there's little difference between diesel, kerosene, and heating oil, from a chemical standpoint,and are pretty much treated the same for transport purposes.
But what do I know... I'm just a dumb truck driver.Lav-25, RockinChair, tscottme and 1 other person Thank this. -
@tscottme
We do our best to follow the rules... Doing what we do, we gotta play it as safely as possible.
Lord knows it's crazy enough out there...
Stay safencmickey, RockinChair and tscottme Thank this. -
FYI - the last item hauled bol should be in the door and your current load bol should be with in your reach. ( so .... you should be placarded with what you got.
If your empty , and going back for another one , then you should be placarded with what you did have on.)tscottme Thanks this.
