Failed DMV test (1st attempt)
Discussion in 'Trucking Schools and CDL Training Forum' started by BigpopperRunner, Nov 12, 2019.
  1. BigpopperRunner
    BigpopperRunner Light Load Member
    198
    103
    Jan 10, 2019
    Feeling pretty bummed out right now, I could have made it to the driving part but nope. I tested out in Fontana, CA I passed the pre-trip, air brake, straight back and offset but failed the parallel (Passenger side parallel). What failed me was that I didn't control the clutch and that I went past the last set of cones 3 times because the area where I was testing at has a slight incline, which caused the truck to roll back when I shifted it to first gear. :( But anyways I got the truck in on my last attempt but ended up not getting through the driving because passing the last set of cones is 10 whole points and your only allowed to lose 12 total haha. Anyways i just wanted to know where are the reference points on the first initial hard left to bring the trailer in? There's only 4 sets of cones (2 in front and 2 in back). I been getting told a few different things, like turn hard left till your drive tires reach the middle landing gear, but others say only turn the wheel half way where was others say turn only 1 turn left. Thanks for the advice!
    truckdriver31 Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    73,334
    164,833
    Aug 28, 2011
    Henderson, NV & Orient
    Lots of failed tests in California, Illinois, New Jersey.
    It's as if those states have a quota to meet.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Buy a toy. Set up a table top testing spot manuver toy into that spot using just your finger on the steer axle.
    Once you understand via the toy how it behaves every time and if the markers are to scale with the size of your toy, usually around 1/45 or so...) you will begin to learn what you can expect in your mirrors.
    seagreg and truckdriver31 Thank this.
  5. BigpopperRunner
    198
    103
    Jan 10, 2019
    I watched a few videos and i learned what i did wrong, I noticed I had too much space on my passenger side, which means I didn't hold my initial left turn long enough, I only made half a steering wheel turn. Most videos are cranking it 1 full turn till the drive tires meet the middle landing gear.
    truckdriver31 and x1Heavy Thank this.
  6. BigpopperRunner
    198
    103
    Jan 10, 2019
    it's true, 99% of the students at my school failed the first time, even the really good ones with experience and had to renew their CDL also failed. But your right about quota, its all about the $$$$
    Chinatown, truckdriver31 and x1Heavy Thank this.
  7. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Those steering wheels are made to be cranked. Once you get your license and are confronted with really tight places, you will be not only cranking that wheel stop to stop but you will be gently at times forcing the tractor beyond normal limits of steering.
  8. BigpopperRunner
    198
    103
    Jan 10, 2019
    Got cha, I am going to crank that wheel next time, but I might not get parallel it might be alley dock next time haha.
    x1Heavy Thanks this.
  9. Traveling
    Traveling Light Load Member
    82
    114
    Sep 13, 2019
    Also, there could be a difference in criteria.
    Before I got my CDL, instructor at a local truck driving school in Kansas City MO told me I was lucky to live on the Kansas side of Kansas City (Kansas City KS) because of the way the examiners were/the test was set up, it seemed it was easier to get CDL in Kansas than Missouri, the state line goes right through the middle of Kansas City metro area.
    Chinatown Thanks this.
  10. Traveling
    82
    114
    Sep 13, 2019
    Different schools use reference points differently, what one instructor may tell you is the right spot to start turning the wheel at, the next instructor from the same school may pinpoint it to a spot a few inches back/left/right and instruct you how to turn the wheel accordingly, both approaches end up being right while their set ups slightly differ, don't let different approaches confuse you.
    Use your free get-out-and-looks.
    nredfor88 Thanks this.
  11. nredfor88
    nredfor88 Road Train Member
    1,801
    6,096
    Sep 26, 2019
    USA
    If 99 percent of the students are failing, I’d question the techniques the school is teaching. Also, if it’s all about the money everyone would be passing so more cattle can come through the revolving doors. :)
    On the retry definitely use your pull ups and get outs, even extra ones. They cost less than cones. Good luck.
