Factory pto air dump overide
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tjshaulingllc, Jun 12, 2019.
  1. tjshaulingllc
    tjshaulingllc Bobtail Member
    I have a 2018 T880 triaxle dump truck with a factory dash mounted pto rocker switch. Is there a way to stop the air suspension dump when I turn on the pto?
  3. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Is there a separate suspension dump switch? And are your switches air or electric?
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Need ESA to turn interlock off.
    pushbroom and Goodysnap Thank this.
  5. Davidmorales13
    Davidmorales13 Bobtail Member
    I have the same issue with a 2012 Peterbilt 388. I only have a PTO rocker switch that Also drops the suspension at the same time. I want to separate that and have a different switch for just air suspension purposes.
  6. Davidmorales13
    Were you able to figure it out? I have the same issue with a 2012 Peterbilt 388. I only have a PTO rocker switch that Also drops the suspension at the same time. I want to separate that and have a different switch for just air suspension purposes.
  7. W923
    W923 Road Train Member
    1,290
    3,922
    Feb 28, 2022
    Need to see it they’re air switches or electric over air.
    If there air switches you take the dash apart and add a switch then figure out where the lines split to suspension dump and pto on and run separate lines from there to the respective switches.
    If they’re electric it might get complicated. I would try to find where the solenoid valve’s are located there’s likely one for each function and you can run separate wires and switches. Hopefully it doesn’t go through some type of computer module it might if these are automatic or auto shift trucks
