F550 Off-Road payload capacity
Discussion in 'Expediter and Hot Shot Trucking Forum' started by waterboy222, Apr 2, 2013.
  1. waterboy222
    waterboy222 Bobtail Member
    8
    Tulsa, OK
    I hope this is in the right forum, I haven't had much luck finding an answer anywhere.
    I own an oilfield dust control company. We spray products on the lease roads to help keep the dust on the ground and not in the neighbors homes. Having a larger truck like a single axle tractor makes it almost impossible to do our smaller jobs (arenas, ballparks, etc) so I'd like to upgrade to either a Ram 5500 or an F450/550.
    We just finished up a job where we had to do 78 truckloads of product, utilizing our 500gal tank, and really lost our butt because of how long it takes to refill each time. I'd like to have a tank that can carry 1600 gallons. At 11.5 #/gal, that puts the payload at 18,400 lbs not including the boom, tank, pumps, hoses, fittings, etc. I know this is over the capacity of the trucks rating. I know it would be illegal to haul that much on the road, but for offroad low-speed spraying, is this still too much weight for the truck? Its never rough areas, always smooth since its just been graded and compacted. I know a regular watertruck is ideal for these kind of jobs but considering they dont' make up very much of our business, I can't see spending the money to have a piece of equipment that only gets used for a handful of jobs per season. An F450/550 would really be the ideal candidate. Even if I only filled the tank to the legal limit for smaller jobs, having the extra capacity for bigger jobs would really help a lot.
    Any advice?
    Edit: (To clarify, we wouldn't overload the truck for highway use, only when we are filling the truck from our bulk tanks off-road)
  3. TruckingSurveyor
    TruckingSurveyor Light Load Member
    133
    43
    Jan 28, 2013
    Oregon
    I don't know if the payload numbers are out on the upgraded 2013 Ram C&C trucks yet, BUT found this: "Ram Chassis Cab trucks also deliver maximum capability with best-in-class towing and GCWR figures 29,600 pounds and 37,500 pounds, respectively (5500 model)."
    With a GCWR of 37,500, the payload on the truck has to be getting up there near what you are looking for.
    TS
  4. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    What about a tag a long trailer with a tank and sprayer setup mounted on it. On the small job just take the truck and the larger jobs take both........
  5. TruckingSurveyor
    133
    43
    Jan 28, 2013
    Oregon
    Cat, I thought of suggesting that too, BUT it may be a pain maneuvering during a spraying job? On the new Ram's with a 29,600 trailer weight rating it would have enough grunt for sure for the numbers the OP was talking about.
    TS
  6. waterboy222
    8
    Tulsa, OK
    We have a trailer now that has a 2500 gal tank on it and it NEVER gets used because its such a pain in the butt to maneuver. The trailer works really well but its limited for what we want to do. If we are covering large areas like long roads, it works great but trying to get up in the corners and around buildings backing a trailer in to spray is a LOT of work.
  7. Ridgeline
    22,101
    113,190
    I would call your local Ford truck dealer and ask them to send you a sales package with an upfitter's guide. IF not, call Ford directly and ask for one of their specialist to help you out. I would stick to Ford. I think the F550 may just squeak under the max payload of a 1600 gallon tank.
  8. waterboy222
    8
    Tulsa, OK
    According to the Ford website I can get a "payload upgrade package"
    That still doesn't tell me what my payload would be without knowing the weight of the truck, right? To find out what my payload would be I would need to take 19,500 - Truck Weight = Payload Is that correct? That only gives me 12,XXX Payload according to them.
    That would give me enough capacity for 1043 gallons of product. So a 1000 Gal tank plus pumps, hoses, the steel flatbed, driver, fuel, spray boom and washdown tank will still only allow me (legally) about 900 gallons of product (10,350lbs).
    900 Gal of product would be great for the majority of our jobs. However, when Im offroad doing a long road job I'd like to put about 18,000 lbs of product on the back of the truck. My concern is that I will tear up leaf springs or be dragging truck parts or wearing out bearings. In your opinion, what kind of weight can the truck carry off-road at low speeds of around 7-9 mph without tearing things up?
    Reference 2013 F-550 Payload Capacity Chart:
    http://www.ford.com/commercial-trucks/chassis-cab/specifications/payload/
    But on THIS page it says the 5th Wheel Hitch Weight limit is 24,800
    http://www.fordf150.net/specs/05sd_specs.pdf
    Im confused.
  9. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The fifth wheel chart it for towing weight . The 24 k number , only half would be on trucks frame . Which is constant with the payload chart. International makes a lopro model that would be almost as easy to get round in ? Not sure of the model number . Hope this helps .
  10. waterboy222
    8
    Tulsa, OK
    To get into a new truck like a topkick, sport chassis, or single axle truck that has 4x4 is a small fortune... Just out of reach for us.
  11. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    hey waterboy, that's a lot of vertical load for that axle on those trucks. Best to go look at a truck you are interested in at dealer, read what the door jamb says for GVWR per axle to give you an idea. Have you considered used F700-800 4x4's? Former power company truck or similar mod with your needs. I see them sometimes on Ga for sale.
