External microphone kenworth dea700 radio
Discussion in 'Questions From New Drivers' started by ad356, Mar 13, 2022.
  1. ad356
    ad356 Road Train Member
    2,138
    3,179
    Mar 13, 2017
    Whatever bult in microphone these stereos have is terrible, its unusable to have for decent hands free calling. There is a jack in front of the stereo, can anyone tell me if that's a microphone jack and if it is, is it a 3.5MM to 2.5mm jack. They sell both sizes. If I could use an external microphone I think this would work much better. My previous truck had a DEA500 radio and had decent hands free calling. It also had a visible microphone mounted to the corner of the windshield, I cant even tell you where they moved it to... I wished they just left the stereo unchanged. The older style was bettet
    tscottme Thanks this.
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,499
    Oct 22, 2016
    North Dakota, Eh?
    Can I ask why dont you just buy a Blue Parrot?
    Diesel Dave and Speedy356 Thank this.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    They are useless in every truck I have tried them in. Old and new Cascadia, Mack 613 and Peterbilt 379. And KW 800.
    Crude Truckin' Thanks this.
  5. JoeyJunk
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    This was an enjoyable part of working in the oilfield. Got to try out a lot of different makes and models, brand new to boot.
    Brettj3876 Thanks this.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    And anyone who puts a 10sp road tractor in the oilfield needs to be shot Lol. Us-well services had some Macks that were former road trucks. Had no business in the oilfield. Taking off on a steep hill they would stall unless you have it some fuel
    JoeyJunk Thanks this.
  7. JoeyJunk
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    I was with them when they first started. Beautiful brand new Peterbilt’s……with 9 speeds. Every TX based oilfield company specs the #### trucks for flat land. I complained about it quite often LoL.
  8. Brettj3876
    11,257
    54,056
    Nov 18, 2014
    Land of local
    I was in them too. At least with the 9sp Low is lower than 1st in a 10. They had a few T800 with 18s
  9. tscottme
    tscottme Road Train Member
    The jack on the front of the DEA 700 is for Auxiliary-Input. It allows you to plug your phone or mp3 player headphone jack into the truck stereo and listen to that device using the truck stereo as a sound system.
    The DEA700 sucks for several reasons. I never knew anyone that expected to use the truck's built-in mic and speaker to make phone calls. Everyone I know used some sort of bluetooth headset or earpiece for BT phone calls. BTW, the DEA700 will eventually forget it was paired to your phone or headset about once every week or two. The DEA700 will not pair to a new device while truck is in motion. To keep the DEA700 behaving well you need to leave the truck key turned off, not accessory, but off like the key is in your pocket off, every day for a minute. If you don't the DEA700 will eventually forget that your BT headset was only supposed to be used on calls and your phone was only supposed to provide audio. It may reverse those settings, or just not pair.
  10. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    On the DEA700 radio there is a plug in the rear of the head unit for the external microphone. I actually have a spare mic in my truck. Pull the head unit out and see if the plug is empty. If so, then pick up the correct mic and route it close tou your head. I put mine directly above the visor.
  11. kemosabi49
    10,435
    44,381
    Jan 13, 2013
    SW Arkansas
    I have a DEA500 in the Cornbinder I'm driving and the Bluetooth is just ok. The mic is on the "A" pillar and I have to remember to talk in that direction or the other end can't hear me.
    But the worst thing is that somehow, it keep turning the ringer volume all the way down so if I don't happen to be glancing at the phone I keep missing calls. Also, don't notice when I get out so I keep missing calls until I get home and the wife asks me why I don't answer her calls..
    tscottme and JoeyJunk Thank this.
