Extended Oil Change Intervals, who's doing them?
Discussion in 'Ask An Owner Operator' started by ProfessionalNoticer, Aug 28, 2021.
  1. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Who's doing them without a bypass? I'm stretching out my drain interval from 10k to 30k but I'm not running a bypass filter. So I'm wondering if I should be changing my regular oil filter anyway even though the oil is being used longer.
    I'm also seriously switching over to full synthetic. There's some Chicom Sinopec 15w40 by the 4.75 gallon pail for like 50 bucks shipped at Walmart.
    On my pick-up, I run a MobilOne extended life oil filter since I drain the oil less frequently now. Should I be looking for something like that on my KW?
  3. Long FLD
    Long FLD Road Train Member
    11,353
    45,697
    Mar 4, 2015
    What engine do you have? Are you doing samples?
  4. slow pok
    slow pok Light Load Member
    144
    211
    Oct 27, 2013
    lizela ga
    When u go synthetic u stay synthetic no going back . Seals shrink
    ProfessionalNoticer Thanks this.
  5. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    E model Cat. Affirmative on the samples. Just did my first one after a fresh Platinum kit. Other than silicon being elevated everything looked good.
  6. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    I heard that was only with the high mileage blends. Glad I asked.
  7. skallagrime
    skallagrime Road Train Member
    3,836
    9,877
    Apr 10, 2012
    Indiana
    no idea exactly what happened, didnt know enough then, and even now, oil isnt something ive done a deep dive on, all i can say is i had a 3406e that needed a rebuild 3-4 weeks after a shop ignored my instructions for a 15-40 non-synth and put in their synthetic.
    This IS an anecdote and as i stated, at the time i didnt know as much as i do now, but it never used or leaked a drop before they did the synthetic, 1.5 weeks later, started dripping here and there, at 3ish weeks, forbidden pudding in the oil fill tube.
    Do not recommend
  8. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    It could just be the brand of oil and not the synthetic part.
    I don't think synthetic vs. non matters.
    Brand of oil most definitely matters.
    86scotty and ProfessionalNoticer Thank this.
  9. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    I run Synthetic in my pickup and it's been awesome. Wish I had made the switch earlier.
    bzinger Thanks this.
  10. Ridgeline
    22,101
    113,189
    change you filters at the half way point.
  11. Ridgeline
    22,101
    113,189
    Wrong. if the oil has the same API rating, then there isn't going to be an issue with seals.
    Wespipes, jason6541 and 86scotty Thank this.
  12. jackoboyo
    jackoboyo Light Load Member
    218
    307
    Dec 30, 2014
    MYTH !!!!
