Explain primary and secondary air tanks to me
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bdog, Dec 24, 2015.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    My truck has two air tanks a primary and secondary. I have separate gauges for each and they do not always have the same pressure in each. One would think the air pressure would equalize between the two and they would be the same. Is one isolated by a check valve or something? Just curious conceptually how it is set up.
    If I was going to plumb in something like train horns or a coupler to hook up an air hose for tires and such which tank would I want to come off of?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,430
    Aug 26, 2014
    You can probably search Bendix and get a complete break down. Basicly 3 tanks. Wet, primary, and secondary. All have back flow check valves. Big horn probably off wet tank or an add on tank feed from the wet tank, with a restrictive feed port, so it does not compromise brake operation. Coupler: Either dry tank.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yes, the two system are totally separated by check valves. It is a slip system so if you have a massive leak in one system, you still have pressure in the other for your brakes. Primary is normally only your rear brakes and secondary is usually your front brakes and all your accessories. Usually axillary stuff is plumed from the secondary system.
  5. BoxCarKidd
    4,418
    6,430
    Aug 26, 2014
    Yes, but the trailer also functions off the secondary side and train horns are not usual auxiliary stuff. I was just thanking that if there was a justifiable need for a lot of horn action the brakes might be getting an equal work out. Would not want to lose any brake operation for a horn and it might be best on it's own system. Tank, check valve and maybe a valve to control air flow pressure similar to PTO's?
  6. truckdad
    truckdad Road Train Member
    2,020
    16,622
    Dec 14, 2014
    Penn Valley, CA
    cnsper Thanks this.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If you're interested in learning how air brakes work, I highly recommend www.brake-school.com. It is from Bendix and free to register and take courses. Once you register, the first one you want to take is the System Training course that covers all the basics.
    BoxCarKidd and Heavyd Thank this.
  8. KABKA3
    KABKA3 Bobtail Member
    20
    17
    Aug 26, 2017
    On all of these Truck/Trailer Air System Diagrams there is no Air Bags, as if Air Bags are not a part of air System. Why?
    My cab air bags and on drives are not inflated, also secondary air tank is empty and cant build up pressure and engine fan is on all the time. I can't find a diagram which explains how air bags are supplied.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    No they are independant.
    Wet tank gets first air.
    Air dryer gets the dry air into the secondary.
    Taken from TTR post approximtely 2015. Computer hung up on my end across desktops so I patched it straight in.
  10. BoxCarKidd
    4,418
    6,430
    Aug 26, 2014
    It has been 10 hours. Got that worked out?
  11. KABKA3
    20
    17
    Aug 26, 2017
    Not yet. I'm still trying to figure it out by myself. I also have no air in Driver and pass. seats and no air horn.
    I think it might be one of the check valves that goes to one of the tanks, or Pressure Protection Valve on the faulty tank.
    When I dropped my truck for 2 weeks everything worked fine, no problem, but when came back to charge the batteries and turned the truck On then I saw this problem. The truck is still driveable under 5mph, without Airbags I feel every stone on the road.
