Expedite with a straight truck?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Cy Ran, Feb 13, 2013.
  1. Cy Ran
    Cy Ran Light Load Member
    147
    85
    May 20, 2012
    So Cal
    Why are many Expedite trucks class 8 with sleeper and a 23ft (+/- a few feet) van on a straight truck? What is the reason to not just have a Class 8 tractor with sleeper and pull a similar size fifth wheel trailer?
    I’m not a truck driver, just researching the industry as a future career change and looking at all the options. After someone pointed out the Expedite segment, and some research it’ looks to have some added appeal.
    I tried to do a search, but didn’t come up with a good ’search phrase’.
    I did find this site http://www.expeditetrucksales.com/tips-on-buying.php which was informative, but didn’t address the question I had.
    Thanks.
  3. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    Some expediting companies do use tractors and semi trailers. Panther II is one I've seen that do. The reason for using Vans, Sprinters and straight trucks is that expedited loads are often fairly small loads that have to be there asap. No time to look for other partial loads to fill a semi trailer. It may be a part to get a machine back up and running in a factory. Not very big, not very heavy, but very much in a hurry.
    Cy Ran Thanks this.
  4. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    We used to get Vans and Straight Trucks where I used to work.
    I worked in Receiving.
    We would get one Box of a Part just to keep the Assembly Line(s) Running.
    Could be a small Box or a Big Box or a few Pallets.
  5. frontrange
    frontrange Light Load Member
    78
    190
    Nov 18, 2010
    Northern Michigan
    Also, the straight truck only requires Class B CDL versus Class A for tractor trailer
    truckon Thanks this.
  6. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    That's right . Why pay the cost of maintaining a trailer when it's not needed . Straight truck drivers enjoy better parking options . I've read posts where they parked at campgrounds or in hospital parking lots and eating at the cafeteria .
  7. Cy Ran
    147
    85
    May 20, 2012
    So Cal
    THANKS everyone for the input. I was thinking I'd get one reply, but I like all the info.
    Some of the replies give me more questions, so I'll do a little research and see what is already on this site.
    Thanks again.
  8. rollin coal
    rollin coal Road Train Member
    13,080
    25,852
    Mar 29, 2008
    TN
    TT in expedite is a hot commodity. There are at times full truck load expedite. There are also times when cargo van or straight truck "load", one pallet or whatever pays big bucks and goes on TT when they can't get a smaller truck. TT gives you versatility Competition is fierce with cargo vans and rates are cheap. Good money to be made with a straight if you know or figure out how to run it.
  9. Cy Ran
    147
    85
    May 20, 2012
    So Cal
    Is 'TT' short for 'truck n trailer'? I did a search and got 'tandem trailers'. My wag is Truck and trailer, but don't want to assume.
    In my unknowing opinion, a tractor with sleeper would open up options, like a flatbed or enclosed trailers depending on available loads. I did like learning that a straight truck has some better accommodation(s) options. I also ran across some talk about in bad weather a truck n trailer has more of a Jackknife hazard.
    I guess there is pros and cons either way, if there was a 'perfect rig' there would only be perfect rigs hauling everything.
    Thanks again for the replies.
    I have been very busy at work which cuts into my internet time. Ha Ha
  10. TennTrucker
    TennTrucker Light Load Member
    250
    168
    Aug 20, 2010
    Dresden, Tn
    My unit is a class 7 but has a Cat C9 in it, which is larger than most class 7's. Has a loaded 96 in. sleeper, even has an auto tracking Directv system.
    Sent from my DROID X2 using Tapatalk 2
    garylobo Thanks this.
  11. rollin coal
    13,080
    25,852
    Mar 29, 2008
    TN
    "TT" tractor trailer, "ST" straight truck. 53' dry van trailer with logistics posts is what you want with tt. There is flatbed andor stepdeck expedite but not so much,sort of a niche within a niche. You want to go where the money is at. Jackknifing or accident in general can happen to any vehicle. There's good money expediting with TT or st but no-one is going to just give it to you, you have to learn, get experience.. Would avoid cargo vans like the plague the market is flooded with those it takes very little capital to get up and running a cargo van and rates reflect that.
