Mid128pid173fmi5,2,0 going active and inactive, Pyro temperature between 600&1000.will this prevent my regen to work?.pls help
Exhaust temperature to high
Discussion in 'Volvo Forum' started by Benek, Jan 25, 2017.
What year is the truck and how many miles? Have the doc and dpf ever been cleaned? Is it regen'ing normally? Hows the power? Is it boosting normally?
Honestly your best bet is take it to a shop and hook it to Vcads and get a proper diagnostic done. I -
The high exhaust temp HET will come in to warn you not to park over an area that could catch fire or over flamable materials. Such as dry grass etc. This is because the regen is very hot. The HET will usually go off. If it happens when I am about to park I will park and idle the engine up a bit until self reden is completed.
