Exhaust Pipes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ker, Jul 8, 2023.
  1. Ker
    Ker Bobtail Member
    25
    16
    Mar 11, 2018
    Hi, my exhaust system goes like this: turbo / 2' straight pipe / 2' flexible pipe /
    5' straight pipe / 2' flexible pipe / 90° elbow etc until it reaches the muffler. You get the idea, it looks like mess.
    My question is: would it be a good idea to put all straight pipes all the way from turbo to muffler, or flexible pipes are the only way to do it because of slight curves and adjustments to these elbows. Since I bougt the truck my exhaust system always looked like this, every few years some flexi pipe goes bad because of rust and I have to replace it, it's pretty annoying.
    One more thing, the only pipes I found on amazon are the ones that are completely straight (they don't have female-male expansion at the end), can I connect those with straight clamps (the ones without ridge) or they can't go gay , they have to be female/male due to leaks?
    D.Tibbitt Thanks this.
  3. Star Rider
    Star Rider Road Train Member
    1,319
    10,638
    Sep 23, 2019
    No! you need the flex pipe for the expansion as the pipes heat and cool. If you put all straight pipes on you WILL crack your turbo or exhaust manifold.
  4. Ker
    Ker Bobtail Member
    25
    16
    Mar 11, 2018
    Wow, I thought my question was stupid (it's an exhaust, pretty straight forward thing) but there's so much behind it. Thanks a lot!
    Bean Jr., D.Tibbitt and Star Rider Thank this.
  5. Star Rider
    1,319
    10,638
    Sep 23, 2019
    Not only that , but the engine is mounted on the frame, most mufflers are cab mounted. With air ride cabs moving up and down you need that flex.
  6. 201
    201 Road Train Member
    12,058
    24,619
    Apr 16, 2014
    high plains colorado
    I agree, but be sure to get stainless flex tubing, and that ain't cheap. No need for an adapter, the flex is a bit larger to fit over the pipe.
    Bean Jr. Thanks this.
