Exhaust manifold leak violation?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mikesuburban1, Nov 25, 2019.
  1. Mikesuburban1
    Mikesuburban1 Bobtail Member
    43
    13
    Dec 30, 2016
    Rockland county ny
    Truck has a bad exhaust manifold leak near the rear of the motor where the dog house clips together in the cab. Is this a violation? Is it going to hurt the truck at all?
  3. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Not sure if it's a violation, but it's not good. You're losing some power as exhaust pressure turns your turbo. And there's a better chance the fumes will get into the cab. Which could kill you depending on the situation. Best to bite the bullet and get it fixed. Then there's no worries.
  4. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    if it allows exhaust into to cab, what do you think..???
    have it checked out for either a cracked manifold, or blown gasket, and get it fixed?
  5. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    393.83(e) Improper exhaust discharge (not rear of cab) Exhaust Discharge 1 point = Yes violation
    393.83(f) Improper exhaust system repair (patch/wrap) Exhaust Discharge 1 point =Yes violation
    393.83(g) Exhaust leak under truck cab and/or sleeper Exhaust Discharge 1 point =Yes violation
    what ever any DOT cop wishes to bang you for
    https://csa.fmcsa.dot.gov/Documents/SMSMethodology.pdf
    x1Heavy and Cabinover101 Thank this.
  6. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    Get it fixed. Soon.
  7. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    Tape the beguezus out of the dog box along the seams until you get it fixed. It wont stop an OOS, but it can delay you breathing in the fumes.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Newer trucks that will mess up the emission system too.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Turn that cab into a gas chamber. Wonderful. You wont even know you are dead. Maybe 15 minutes if it is all closed up in there.
    Thats OOS to me. Fix before sending out with anyone on anything.
    buddyd157 Thanks this.
  10. Mikesuburban1
    43
    13
    Dec 30, 2016
    Rockland county ny
    Truck is going in today to get fixed
  11. Bludhini6205
    Bludhini6205 Bobtail Member
    4
    2010 prostar losing power. Everything was fine until I replaced the crankcase breather. It was leaking. No that's replaced now engine warn light on when I push the pedal down. If I turn on and off light goes off. It's a small lose of power. On the up and up hills I lose a lot. I am still getting good speed. Will the crankcase breather make you loose power?? Hopefully someone can help thanks
