Exhaust leak?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by finbyrd, Jan 3, 2016.
  1. finbyrd
    finbyrd Light Load Member
    152
    87
    Apr 13, 2015
    Has anyone had experience dealing with an exhaust leak? Whenever my truck went to do parked regens or those little mini regens the last few days I could smell exhaust in my cab. It actually woke me up the other morning in Wisconsin and I had to roll the passenger window down all the way and stick my head out into the cold air. At the time I thought it was merely sucking in air from the truck next to me as it has done from time to time. Well this morning the truck next to me wasn't running and there was no one on the other side of me so I ended up having to shut the truck off mid regen. I figured it would be ok as it can do a passive regen when I start down the highway. For some reason it refused to regen after nearly two hours on the highway. So I pulled into a truck stop where there wouldn't be any access to another trucks exhaust and began a regen. Sure enough ten minutes into it I begin to smell exhaust in the cab so I immediately shut the truck off and call breakdown. The mechanic they send out does a regen but says he didn't smell any exhaust so now I have no idea what to do or what's going on. All I know is I've had a splitting headache since this morning that has not gone away and I feel nauseous and sick and would just like some outside opinions.
  3. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Usually the flex pipe behind the turbo, under the cab has cracked somewhere and is leaking.
  4. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    I smell it too. Turn your truck off or park in the open. Headaches ...yep.
  5. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
  6. Confused
    Confused Light Load Member
    224
    270
    Sep 22, 2009
    somewhere else
    I agree with ^^^
  7. truckthatpassesyouby
    1,876
    6,124
    Jun 3, 2015
    I don't think so. Perhaps it's because this truck has the pipe-end underneath the cab.
  8. EZ4U2SAY
    EZ4U2SAY Light Load Member
    68
    22
    Nov 28, 2015
    Well more than one this year alone has died in there cab due to carbon monoxide, my recommendation to you is get a carbon monoxide detector. I'm sure I'll catch hell for saying it but diesel exhaust creates #### tons of pollution, your head ache is a symptom of exhaust exposure. The truck needs to be check out before you do...And yes I know carbon monoxide produced in a diesel engine is negligible, but It has happened and it will happen again. Theres tons of medical research papers related to diesel exposure the chemicals it produces aside from carbon monoxide and its effects. And not I'm not in favor of useless emission systems that add cost to me and the rest of us. Just should know the environment in which you costume air from......
    truckthatpassesyouby Thanks this.
  9. EZ4U2SAY
    68
    22
    Nov 28, 2015
  10. finbyrd
    152
    87
    Apr 13, 2015
    Yeah this truck has the pipe end under the back of the cab too but I've had it for four months now and this has never been an issue. I tried looking at the exhaust system but can't see much myself. Talked to a mechanic and he said maybe the regen system is clogged and pushing it back into the truck when it does regens. Ok, but I started her up this morning and just about fifteen minutes ago I could smell exhaust again (it wasn't doing a regen) and had to shut her off and open the windows. If it was coming from another truck I should still be able to smell it when I open the windows but I can't so it's got to be from my own truck. Well my headache is back again and I don't know what to do about this.
    I did notice yellow liquid pooled under the end of the exhaust pipe; is that normal? Or a side effect of regens?
  11. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    The freightliner i was driving had a leak in the exhaust manifold. Turned out to be a tiny crack that was difficult to find. The manifold was replaced and no more issues. Exhaust manifold cracks and warpage problems are common. Look all around and under truck for leaks. Get a wrench and tighten bolts, clamps, etc.
