Hello everybody.
2017 Freightliner Cascadia, DD15 470k miles. Have been owning the truck for 9 months. No coolant/oil loss observed for that period of time. Coolant's color was pretty much normal, no smell or white smoke at all. Oil tested every 30k miles. No signs of coolant in oil. Slightly elevated Fe and Al. Had high silicon, but determined that it was contamination from the oil test pump. When the sample is taken by direct drain, silicon is normal.
Last week the radiator started leaking, appears to be a smal crack on a plastic top. Had to replace the coolant reservoir as well as it started falling apart when was taken off.
So I bought the gas test kit and ran the test. The liquid turned from blue to green. I assume there is an exhaust getting in the coolant. What keeps me wondering is why no coolant's been lost? In my understanding if there is an intercharge between two systems it should work both ways - if exhaust's getting into coolant there should be coolant getting to the system which leaks the fumes.
Exhaust gas in coolant?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by AlRod, Sep 7, 2021.
EGR cooler is place to look first. When DPF is full or engine brake event exhaust gases pressru is high and can pressurize cooling system. When exhaust gases pressure drops some coolant can go inside EGR cooler then in exhaust or in engine if EGR valve open. Coolant evaporates water in hot DPF and coolant chemicals plug DPF even more.
Disconnect EGR valve from EGR cooler and look for coolant traces.AlRod Thanks this. -
I don't trust those kits. I probably still have one in the stuff from my old repair shop. Signs of an exhaust gas leak into coolant: Cooling system will be pressurized within a couple minutes of starting the engine. Once warmed up, with the radiator cap off, you will see constant bubbles coming through the coolant, to the outlet (they may not come out till the thermostat opens, because the thermostat can hold the "air" behind it).
So, I took the truck to Freightliner. They ran a test and it didn't show contamination in coolant. No I am puzzled. Shall I give them the benefit of the doubt or take to some other shop? Can't decide
You're looking for a solution without having a problem. Drive the truck.AlRod Thanks this.
